Advice please, Problem with assembly
4 replies to this topic
#1 Matty B
Matty B
    Eat, Live, Breath Subaru
  • 342 posts
  • Swansea Tasmania
Posted 08 October 2004 - 04:26 AM
Guys, I must be doing someting wrong here.
I am putting the two halves of an EA81 together and the crank spins nice and smooth until I start torquing up the bolts. even at the 2nd last round of nips the crank won't turn.
Is it possible the bearings are slightly too tight around the crank.
I have backed off all the bolts and the case is still tight together, and now the crank turns.
Is there a trick, I am going in the correct order....
I have had it apart twice now to check,
Its starting to s..t me, I thought I would have a coffee and ask you guys.
Any suggestions?
Cheers
#2 canajun2eh
canajun2eh
    USMB is life!
  • 222 posts
  • Ottawa, ON, Canada
Posted 08 October 2004 - 04:55 AM
That happened to me once, but not with a Subaru.
It turned out that the main bearing "halves" were not identical, and that I had mixed them up.
Check the bearings carefully -- there's probably a "left" and a "right" for each of them. Remember also that in automotive terms, "left" and "right" are determined when you're sitting in the driver's seat.
Good luck.
#3 Matty B
Matty B
  • 342 posts
  • Swansea Tasmania
Posted 08 October 2004 - 08:01 AM
All sorted Thanks.
#4 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,101 posts
  • East Coast
Posted 08 October 2004 - 10:31 AM
what was the problem?
#5 canajun2eh
canajun2eh
    USMB is life!
  • 222 posts
Posted 09 October 2004 - 05:16 AM
Parallel thread in the Australian board. http://www.ausubaru....iewtopic&t=1077
Problem was an improperly seated bearing shell, caused by a burr on the bearing seat.
