turbo tranny swap
16 replies to this topic
#1 stngllhm
stngllhm
    Subaru Fanatic!
  • 367 posts
  • Casper
Posted 12 October 2004 - 11:10 AM
i've got a dual range tranny and 3.9 diff i would like to put in my 87 gl-10 wagon is there any differance in how strong the d/r is in ralation to the 5 speed on-demand i have in there now. so in short if i do the swap is the d/r going to hold up i was told that the turbo tranny is built more heavy-duty that is why i am asking
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 12 October 2004 - 11:19 AM
It will bolt right in.It will hold up. I haven't seen anything that suggests to me that the turbo pushbutton tranny is stronger than the N/A PB tranny they used , or the the D/R tranny.
Just be sure to put the matching rear diff in.
#3 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 12 October 2004 - 12:31 PM
Any axle/spline/size issues that need to be considered? I know there are differences MT vs AT, how about turbo vs non-turbo?
#4 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 12 October 2004 - 02:36 PM
actually you will need the NA axles that come with the NA trans...front ones only tho. The rears are the same regardless.
23 spline count for the NA and all autos, and 25 for Turbo 5MT FT4WD, 4WD, and XT Turbo 2WD and 4WD and FT4WD
#5 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 12 October 2004 - 02:38 PM
Doh! forgot to mention the axles.. thanks will
#6 stngllhm
stngllhm
    Subaru Fanatic!
  • 367 posts
  • Casper
Posted 12 October 2004 - 02:40 PM
well that sucks the cvs with the d/r are bad and the one on my turbo are good. what about the hubs
#7 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 12 October 2004 - 02:41 PM
Hubs are the same...85-94...DL, GL, GL-10, RX, XT, Leone, Loyale...NOT XT6 tho.
so are the CVs completely destroyed? I wouldnt think so...take them apart...clean them...repacc with subie grease....put subie CV boots on them, and clamps...and install away!
#8 stngllhm
stngllhm
    Subaru Fanatic!
  • 367 posts
  • Casper
Posted 12 October 2004 - 02:48 PM
the splines on the hub end are thrashed pretty bad.
#9 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 12 October 2004 - 02:49 PM
oh...
well...see if the outer CVs from the turbo ones will fit the shafts on the NA ones...ive never tried that....but it might work....
#10 stngllhm
stngllhm
    Subaru Fanatic!
  • 367 posts
  • Casper
Posted 12 October 2004 - 02:55 PM
isn't the inner joint easier to get apart
#11 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 12 October 2004 - 02:58 PM
depends...could try that too...
2 things to get the DOJ off...a big circlip deal in a gap on hte DOJ cup...and then an internal snap ring on the end of the shaft holding the DOJ balls and cages on. The CV...secure the sahft...and gently beat the CV assy off the shaft...pops out.
#12 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 12 October 2004 - 06:14 PM
oh...
the doj from a 3at turbo axle is the same diameter as the 25 spline axle, but it has a 23 spline count. this way you can have a 23 spline axle that has the turbo durability.
if you decide to but new axles altogether order for a turbo automatic 3spd, any model, as long as its not for full time autos(4spd)
#13 PoorManzImpreza
PoorManzImpreza
    Subaru Nut
  • 546 posts
  • BARBADOS
Posted 12 October 2004 - 06:38 PM
are the full-time 4eat turbo trannies 23 or 25?
#14 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 12 October 2004 - 10:03 PM
25
#15 BobBrumby
BobBrumby
    Subaru Nut
  • 583 posts
  • Brisbane, Australia
Posted 13 October 2004 - 12:34 AM
are the turbo\NA doj the same size ? Cause if thats true could u just use NA doj outer cup with the turbo axles\doj midle-race and bearings.
Do turbo backends e.g. lsd's have the same spline count as NA rear diffs?
#16 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 13 October 2004 - 07:42 AM
rear diffs are the same.
#17 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 14 October 2004 - 05:23 PM
the 23 spline from 3at, the 25 spline from full time 4at and turbo 5spds are the same, as well as xt6.
all you have to do is swap the proper cup end onto the axle you are using, and install a new boot clamp
