Sabre75 Posted October 14, 2004 Share Posted October 14, 2004 Hi Guys and Girls, Just new to this site, I was wondering if it is possible to fit a Ver 4 WRX motor to a 1991 Facelift Legacy RS as the block is still an EJ20T, Will I need to change the Diff and gearbox as well ?????, I have blowen the Compression rings and can get the new motor really cheap but want to know if all the extra work will cost to much Thanks Sabre 75 Quote Link to comment Share on other sites More sharing options...
WJM Posted October 14, 2004 Share Posted October 14, 2004 Hi Guys and Girls, Just new to this site, I was wondering if it is possible to fit a Ver 4 WRX motor to a 1991 Facelift Legacy RS as the block is still an EJ20T, Will I need to change the Diff and gearbox as well ?????, I have blowen the Compression rings and can get the new motor really cheap but want to know if all the extra work will cost to much Thanks Sabre 75 I believe you might, *might*, have to swap the wiring harness over as well.... but if you take the long block of the WRX engine...and put all the Legacy stuff on it...it should work fine... Quote Link to comment Share on other sites More sharing options...
