Whatchya think about the foresters
Im looking at buying a 98 forester....whats the general consensus on these rigs?? Its a sub so its gotta be alright:brow: Any downfalls or known issues with the foresters, or maybe just this particular year??
Also, are there any typical problems, ie timing belts, ect...
Im looking at replacing my wifes 93 honda accord (I know...please be kind and dont bash too hard..;) ) with this forester. I have two young daughters and want a safer, more convenient rig, and it HAS to be a sub.
Thanks for any input.
Patrick
which if you look at the three blown head gasket threads here is to be avoided.
The 99 and up have a phase 2 which has a much better rep. Do a search on this board before you buy.
On advice from the board I bought a 99 with more miles over a 98 with less and I am glad I did.
I own a 99 Forester AT. So far, with 167,000 miles, it has been an excellent vehicle. I do NOT recommend the purchase of the a 98 Forester with the 2.5L Phase I engine. Be aware that the rear seating is somewhat tight in the Forester. It varies from car to car, but expect about 25 mpg with this car on the highway. If you have not owned an AWD car before, READ and understand the operator's manual before you even put the key in the ignition. Good luck.
Hello-
At the risk of offending members, I'm going to candidly suggest that you avoid the 98 forester, similarly any outback with the phase 1 2.5l DOHC. I recently sold my 98 forester, and i can tell you that it was a total clunker. at 70K it had a jerky and hesitant automatic transmission, a front end that despite getting the OK from a subaru mechanic felt loose and rattly - our beater 89 mazda sounded more solid going over speed bumps or parking lot lips. Though it never overheated, it had already started to bubble in the overflow reservoir, and the coolant looked filmy. The trans leaked out a top vent all over the driveshaft, one of the CV boots dried out and disintegrated because it was too close to the catalytic converter ($$!) and the AC cycled on and off every 60 seconds or so. Also, one of the wheel bearings was going woomp woomp, this is a known prob. with this car, and an expensive replacement. Also, the drivetrain, with its transmission and two differentials, had a lot of slack, so when you let off the gas then got back on it, it took a creepy second or two for everything to catch up. Finally, do a search on piston slap. on cold mornings, the 98 forester and most outbacks with the DOHC rattle loudly for the first 10 minutes of driving. don't let anyone tell you that this isn't a problem. I think the east german trabant had a better-built engine than this! (This problem was eliminated in 99/2000 with the introduction of the SOHC, but I gather they still have leaky head gaskets) In short, with all due respect to the vast subaru cult, i don't think these are very good cars. we traded for a toyota truck, and i can tell you not losing sleep at night over a looming headgasket/transmission/bearing replacement/side-of-the-road-stranding is nice. The only thing this car had going for it was its wildly inflated, hype-driven resale value.
good luck. You might consider keeping your honda!
  • 3 weeks later...
Patrick,
I have a 98 Forester L 5spd that had a number of minor problems until recently. Turned 100K on the odo and the dreaded cooling system problems started. I have either a blown head gasket/warped head or a cracked block. From what I gather reading the numerous posts on this topic both here and on other sites, this is a very common problem. The next year wasn't much better as indicated by SOA issuing an extended warranty to cover this problem (see WWP 99 Feb 2004). Given what I know now, I wouldn't consider either a '98 or '99 Subaru.
Mike
