jcole01108 Posted October 16, 2004 Share Posted October 16, 2004 Anyone know if an Impreza 02-04 RS 16 inch wheel will a 2004 outback wagon? I assume the offset will be the issue. Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 17, 2004 Share Posted October 17, 2004 Anyone know if an Impreza 02-04 RS 16 inch wheel will a 2004 outback wagon? I assume the offset will be the issue.as far as i understand subaru wheels fit subarus.. period. shouldn't matter what model. Quote Link to comment Share on other sites More sharing options...
THAWA Posted October 18, 2004 Share Posted October 18, 2004 well, the main issue is the brake clearance. 14-15" wheels wont fit on wrx brakes to the best of my knowledge. But since your current wheels are 16x6.5 and the wrx wheels are the same size they should fit fine Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 20, 2004 Share Posted October 20, 2004 well, the main issue is the brake clearance. 14-15" wheels wont fit on wrx brakes to the best of my knowledge. But since your current wheels are 16x6.5 and the wrx wheels are the same size they should fit fine yes...that factor too. Quote Link to comment Share on other sites More sharing options...
bajavwnsoobnut Posted October 20, 2004 Share Posted October 20, 2004 as far as i understand subaru wheels fit subarus.. period. shouldn't matter what model. unless you have a oldschooler besides the XT6 Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted October 20, 2004 Share Posted October 20, 2004 2005 sti wheels wont fit either - bolt pattern change but yes... 16" impreza rim will fit just fine on an Outback cheers Jamie Quote Link to comment Share on other sites More sharing options...
outback_97 Posted October 20, 2004 Share Posted October 20, 2004 Another one: SVX is a different pattern too, right? Even if the WRX wheels are the same bolt pattern, isn't the offset on the WRX wheels greater than the offset on newer (2nd gen) Outbacks? FWIW, I found this nifty chart a while back when I was verifying that WRX wheels would fit on my TS: http://wac.addr.com/auto/obs/wheels.html I don't think this addresses newer OB wheels, though. Apparently 2nd gen OB's are 48 mm offset. That doesn't mean they won't fit, but they are not "the same" Cool offset calculator: http://toy4two.home.mindspring.com/offset.html Info from Peaty @ scoobymods: http://www.scoobymods.com/forums/showthread.php?s=&postid=10148#post10148 Steve Quote Link to comment Share on other sites More sharing options...
wrxsubaru Posted October 21, 2004 Share Posted October 21, 2004 Another one: SVX is a different pattern too, right? Yep the new 05 Sti now has the SVX pattern, finally some nice wheels should be come available for the SVX in the right offset. Quote Link to comment Share on other sites More sharing options...
