fransi Posted October 18, 2004 Share Posted October 18, 2004 '97 Legacy Brighton Wagon The connector for my passenger side headlight melted. I have only run standard suggested bulbs but this one always seemed to lose the low beams long before the driver-side. Local (No Va) dealership ( dodge/kia/subaru ..in that order) says that the entire bulkhead harness has to be replaced and that the part alone is $462. ridiculous. I have read through a lot of the posts here and I am getting the impression that a mechanic should be able to just splice on a connector. My questions: 1. How do I locate such a mechanic? 2. Is it dangerous to do such a splice? 3. Would this be only a quick fix and eventually I will need to replace entire thing? 4. Does that price quote sound reasonable? 5. How long would it take a decent mechanic to replace the whole thing? Thanks fellas, ~~fransi ps... no I will not do this myself LOL. Quote Link to comment Share on other sites More sharing options...
Cougar Posted October 18, 2004 Share Posted October 18, 2004 You may be able to get a replacement from a local salvage yard. You should be able to splice a replacement in. If you feel up to it you should try doing it yourself. If I was doing this I would try using some none insulated butt splices and solder the wires to it and use heatshrink over the splice, then tape over all the connections. This is a pretty simple job so I wouldn't be afraid to do this if I were you. If you just don't want to do this yourself you should be able to contact a shop that does automotive electrical work and let them do it. Quote Link to comment Share on other sites More sharing options...
