LUVMYBRAT Posted October 18, 2004 Share Posted October 18, 2004 After swapping motors I have aquired a serious leak do to the fact that the new motor did not have the spacer for emissions on it and my exhaust is strained because of clearance issues, there is no clearance it hits crossmember and still wont seat up. Can a serious leak affect performance? other than noise? I put a custom y-pipe with no cat and now with leak it seems to be having issues. I know the path to getting leak fixed it,s just going to be a bit before I can afford the time and was curious? Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 18, 2004 Share Posted October 18, 2004 It's definatly not a good thing to be leaking exhuast right at the heads there. Cuases all kinds of heat stress on surrounding areas. I melted a hole through one of my old timing belt covers this way and darn near melted a timing belt! That is some HOT HOT HOT stuff shooting out there; not good. You are also loosing a lot of power there; just blowing your torque right out the window. I would either get them spacers or re route the exhuast accordingly quickly. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted October 18, 2004 Share Posted October 18, 2004 Which soob? Your turbo? If so, that sound you hear is your power escaping... Quote Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted October 18, 2004 Author Share Posted October 18, 2004 No its my poor brat the thing is really startin to Quote Link to comment Share on other sites More sharing options...
NorthWet Posted October 18, 2004 Share Posted October 18, 2004 Yeah, I figured that it was prob your brat or you would have known. I got a dumb idea... Dumb 'cuz it is prob more expensive and time consuming then just fixing the problem. How about stacking a couple gaskets together? Wouldn't be perfect, wouldn't last, kinda pricey. I am assuming that your long term fix involves re-installing the emissions spacer? Quote Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted October 18, 2004 Author Share Posted October 18, 2004 yea I've got a set of spacers that I'm puttin back in and welding the emissions hole shut, I'm hopin this will cure some of top end issues 55-60mph top speed Quote Link to comment Share on other sites More sharing options...
NorthWet Posted October 18, 2004 Share Posted October 18, 2004 yea I've got a set of spacers that I'm puttin back in and welding the emissions hole shut, I'm hopin this will cure some of top end issues 55-60mph top speed You mean that you think this exhaust leak is causing your top end issues? If so, I strongly doubt it. Thinking timing/tuning/filter for something like that. Exhaust leaks on a n/a car should have hardly any effect on power; probably more of a help at speed than a hindrance. Was the emissions spacer for air induction or for EGR? If EGR, how did you handle the intake side (or was it not present to begin with)? Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 19, 2004 Share Posted October 19, 2004 You mean that you think this exhaust leak is causing your top end issues? If so, I strongly doubt it. Thinking timing/tuning/filter for something like that. Exhaust leaks on a n/a car should have hardly any effect on power; probably more of a help at speed than a hindrance. Was the emissions spacer for air induction or for EGR? If EGR, how did you handle the intake side (or was it not present to begin with)? An major exhuast leak right at the heads there will indeed kill your low end torque and will not improve your top end horse power on any engine. I run those spacers on my EA82 cuz I could only find an EA81 Y pipe. I had to get rid of all my custom setups cuz they all sucked. Just hammer those EGR lines flat and weld them shut. Also get new gaskets as those that are leaking right there are prolly shot now or on their way out. Don't need any gasket between spacer and heads. Good luck! Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted October 19, 2004 Share Posted October 19, 2004 just run open ports:drunk: Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 19, 2004 Share Posted October 19, 2004 just run open ports:drunk: LOL they sure do sound mean with open heads huh? You'll start to feel very sleepy tho from all the emissions coming into the cabin. :-p Quote Link to comment Share on other sites More sharing options...
NorthWet Posted October 19, 2004 Share Posted October 19, 2004 LOL they sure do sound mean with open heads huh? You'll start to feel very sleepy tho from all the emissions coming into the cabin. :-p Thast's what windows are for! Quote Link to comment Share on other sites More sharing options...
