99 2.5L Outback just clicks on both the relay and cylinoid when I turn the key. no sign of drain from jumper battery. no previous signs of bad battery. did happen before and started up strong for a couple of weeks.
what are symptoms of bad relay? bad cylinoid? where would bad connection to starter be? where is the relay?
Thanks,
Pam
PS I'm looking for a shop repair manual for this car too.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
bad Ignition switch or cylinoid
Started by
OlyOutback
, Oct 18 2004 04:52 PM
3 replies to this topic
#1
Posted 18 October 2004 - 04:52 PM
#2
Posted 18 October 2004 - 10:31 PM
If you believe it is the relay you could have someone turn the key and listen for the clicking of the relay. If there is more than one relay just stick your finger on each one of them and repeat the process untill you find wich one is clicking. You could replace it and then go from there. Intermitent starting is the sign of a bad selenoid or bushings in the starter. Take it to your local auto parts store to have it tested. They will be able to give you a solid yes or no as to weither it is bad or not.
Hope this helps.
Hope this helps.
#3
Posted 19 October 2004 - 12:24 AM
You most likely have bad solenoid contacts causing this to happen. The solenoid is mounted on the starter motor. It is the smaller round cylinder on the motor. The contacts can be replaced for a small amount of money.
The symtoms are just the thing you are experiencing, a clicking but no action from the starter. The worn internal contacts won't pass the battery voltage to the motor windings because of the high resistance so the motor doesn't turn.
#4
Posted 19 October 2004 - 04:17 AM
Thank you. The tow truck guy didn't have a flat bed so he jumped in the car did a few quick cranks on the key and the starter motor gave in and started up. He suggested the motor going bad or the contacts.
I'll check the contacts on the solenoid.
