boost Posted October 24, 2004 Share Posted October 24, 2004 Hey, I am back, and with a new problem with the legacy...(btw-it's a 92 non-turbo)... Around 50mph the car shudders really bad going into overdrive, and you have to let out of the throttle a couple times for it to go away. It is an intermittent problem an isn't always there.. Does the legacy have an overdrive solenoid inside the trans that is known to go bad? Quote Link to comment Share on other sites More sharing options...
ShawnW Posted October 25, 2004 Share Posted October 25, 2004 Moved to "new" gen side. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted October 25, 2004 Share Posted October 25, 2004 Sounds like something's gummed up in there. I had this occasionally when I was AT. How old is the fluid in the tranny? You might want to try running some transmission specific seafoam through the auto tranny and see if that helps. Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted October 25, 2004 Share Posted October 25, 2004 Someone chime in because I'm probably wrong, but I'm going with what most auto manufacturers are doing today, which is using solenoids to control all the gear changing. Don't know if your year Subie has a TCU. Sometimes I wish for the good old days when all that was used was vacuum, speed, and throttle pedal position for downshifting. Quote Link to comment Share on other sites More sharing options...
