will a ea81 radiator mount into a 87 wagon?
piece 'o cake.....
drilled 2 small holes (19" centers) and screwed in some plastic plugs I had. put the ea81 rad in, and had to bend up the support lip, to fit the rad under it, then drilled some new holes in the support and bolted the rad up just perfect :)
there is enough clearance that I didn't need to cut away anything for the rad cap, though it is partially hidden. plenty of room to take it off since it sits low.
