Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
XT6 motor into 3dr coupe Update!
#1
Guest_Naz53_*
Posted 23 September 2002 - 10:46 AM
Witte, did you have to cut out clearance in the front Rad support for the AC & Alt.? I did & also the lower front Rad support for the oil pressure sending unit. It's definately a tight fit but I think once I get the other mounts in place it should be alright, then I can put support pieces back into the area's I cut out.
The shifter from the XT6 bolted right into place as well, bonus as I like the gear shift in the XT6. Now once the mounts are done I can begin the task of changing over the wiring harness from the XT6 to the 3dr. If I get my pics scanned in can someone help me post them here? Thanks.
#2
Guest_Witte_*
Posted 23 September 2002 - 10:51 AM
The oil pressure sender I just removed and pluged the hole since I couldn't use it even if the sender wasn't trash.
#3
Guest_Naz53_*
Posted 23 September 2002 - 11:59 AM
#4
Guest_wjmgl10_*
Posted 23 September 2002 - 03:15 PM
What do you two think?
#5
Guest_Witte_*
Posted 23 September 2002 - 03:41 PM
The ALT on mine was close, and I would bet that the A/C was the real problem given its much larger pulley. I used a 4 rib belt that was much shorter since it was right between two different 6 rib belt lengths that were aalible.
Are you using the XT6 pitching stopper?
#6
Guest_Naz53_*
Posted 24 September 2002 - 06:51 AM
Sounds good to me, I took a bunch of my film over last night to get developed of what I have done so far. I could put a real good presentation together in power point, that way I could lable the pictures. Not sure how you would then put them on a website, I'm not good with that. Could you open Microsoft power point files or I could maybe then get it into Word.
Witte,
I'm going to try I have to make a mounting point for it but with that one & the upper rear mount on the tranny it should keep the motor away from the support. When you said you modified your engine mounts how did you have to do it? When looking down into the engine bay from the front did your engine/mounts end up behind the normal points in the cross member or ahead. I tried to use my XT6 cross member by drilling out the same hole spacing as the stock 3dr (placed it over top of the XT6 one) but then the motor sat so far ahead that it wouldn't go back & meet the tranny which was in the stock mount points. So I just used the stock 3dr cross member & it fit OK (just tight at the front which was to be expected).
It's coming along though, wish I had more time at night to work on it, mainly weekends.
#7
Guest_Witte_*
Posted 24 September 2002 - 07:34 AM
#8
Guest_Naz53_*
Posted 24 September 2002 - 09:18 AM
I think I understand what you did now, I'll have to take a look at that tonight. Right now it appears my axles are going to be OK, but I'm going to put the struts & lower control arms tonight to see for sure. I would just like to get the motor back about 1 inch at least. One more quick question on your radiator, the part number you gave me I looked it up & it looks to have angled side tanks & yours appears to be straight sided & the over all dimensions if I remember right are 13 x 26. Do you have the overall dimensions for the one you have, I just found the papers with the two part numbers & descriptions but for the one with your part number it doesn't have the over all size & yours seems to fit real nice. Thanks!!!
#9
Guest_Witte_*
Posted 24 September 2002 - 06:29 PM
BTW the XT6 pitching stopper is a bolt in, if you didn't notice. You have to use both the tranny mount and rod from the XT6. The only part of the setup from the 3dr you will use is the firewall mount which is kinda hard not to use since its a part of the firewall.
#10
Guest_wjmgl10_*
Posted 24 September 2002 - 07:03 PM
#11
Guest_Naz53_*
Posted 26 September 2002 - 10:42 AM
I'll try to get the pics scanned in & labeled & emailed out to this weekend. Some of them came out kind of dark, not sure how good they will scan. Thanks!!!
#12
Guest_wjmgl10_*
Posted 26 September 2002 - 04:12 PM
#13
Guest_Naz53_*
Posted 30 September 2002 - 06:11 AM
Hey man look for the pics this week some time, I had to do some work around the house this weekend before the snow flies, sorry they will be coming. Thanks!
#14
Guest_EJ_*
Posted 30 September 2002 - 06:49 AM
#15
Guest_Naz53_*
Posted 30 September 2002 - 09:59 AM
I am performing the swap, I am documenting the whole thing with pictures & notes as I go. I have to appologize for not getting some pics up yet the project is more or less for fun & the challenge for me as I have other Soobs to drive so I am not in any rush to get it done. I am mainly getting a couple nights a week lately & some on the weekends as I am trying to finish up some things around my house before winter. The conversion is happening though. At this point I have the motor & tranny in place, I have to make / modify the rear tranny mount & also make a place for the front motor / pitch stop mount which was on the XT6 & not the 3dr. The rear end is in place & I have held the drive shaft in place to check length, I will have to put mounts in place for the drive shaft center mounts yet also. Once I have all the main parts mounted I am going to begin the wiring. It's not an easy project as I'm sure Witte & UltimateRX can also say with changing over complete engines but it is possible with time & effort. I have a bonus having a lift i my garage so the car stays in there on it for now.
#16
Guest_Witte_*
Posted 30 September 2002 - 10:52 AM
#17
Guest_wjmgl10_*
Posted 30 September 2002 - 04:54 PM
#18
Guest_Naz53_*
Posted 01 October 2002 - 10:27 AM
The top one yes is no problem, I just have to make the correct length & use the two points you mentioned. However the XT6 also has the lower mount on the front of the motor in front of the oil pan. I plan to mount that also & the 3dr does not have any place for this. I plan to use the bracket from the XT6 & cut & fit it into the lower front clip on the 3dr. I will be strengthening any area's which have been modified & I'm taking pictures as I go so I can put a complete package together to show. I did get motor mounts in last night buy using both the XT6 & the 4cyl mounts. I used the XT6 bracket which bolts to the engine, removed the rubber mount part & swapped it with the 4cyl rubber portion (removing the mount bracket). I had to drill a new hole in the XT6 bracket to fit it in place, I also used the old 4 cyl brackets to make spacers between the cross member & the motor mounts because without them the motor was resting on the cross member. I also had to grind some of the XT6 bracket out to get the mount at the right angle. I am taking pictures also. I just wish I could get more time on it, with winter coming here in PA soon I'll have more time for my garage projects.
