Have an 88 GL 10 wgn. 1.8 Turbo- Auto. Getting ready to change trans. fluid. Is there a drain plug on the torque converter?
Did see the drain plug for the trans.
Don't have a factory manual yet.
Any help would be much appreciated!
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Auto. Trans.
Started by
Guest_watergate528_*
, Sep 29 2002 11:22 PM
5 replies to this topic
#1
Posted 29 September 2002 - 11:22 PM
#2
Guest_Hondasucks_*
Posted 29 September 2002 - 11:52 PM
There should actually be two drain plugs, one up front that drains the front differential (Takes API GL-5 gear oil, don't put tranny fluid in there!) and another in the pan for the ATF.. Note that you may not have a drain plug in your pan, if that's the case then you have to drop the pan and make a huge mess unless you have a big drain pan. Although you might as well drop the pan and change the filter while you're at it.
Just to let you know though, this will only get about 2/3 of the fluid out, the only way to get it all out is with expensive equipment...
If it's really, really, really nasty, you might want to have a shop do a complete fluid change.
#3
Posted 30 September 2002 - 01:29 AM
To clarify...the trans. pan does have a drain plug. Trans. has never had a fluid change..has 56,000 original miles. Noticed hesitation when starting out cold..slight slippage..fluid is red..no burnt smell. Fluid n filter change being done this week! Have the specs for brake band adjustment. Looking at installing an auxillary cooler for the trans. also. That should of been done back in 88!
#4
Guest_Skip_*
Posted 30 September 2002 - 05:51 AM
watergate, I do not believe there is a drain plug for the TC
I had mine power flushed to make sure all the fluid was changed, (60 bucks!!) and the filter is just a mesh
screen - EZ to cleam.
#5
Posted 30 September 2002 - 11:09 AM
Appreciate the replies!
Any one out there have a Factory manual for an 88 GL they want to part with for a few Euro's?
#6
Guest_thealleyboy_*
Posted 30 September 2002 - 01:02 PM
WG:
You might consider leaving your A/T alone if it has gone this long without changing screen/fluid. I beleive this is a 3/36 maintenance interval item, and there is little to be gained 11 years after the last scheduled service.
I have heard lots of bad things about doing a trans fluid replacement this late in the game. Some kind of quirk that is common with sealed hydraulic systems. I too had some suspicious transmission problems after doing a "total fluid replacement" on my 86 4wd A/T wagon. May have just been a coincidence, but I dunno...
If topping off your fluid doesn't cure the slippage, I doubt that a fluid repalcement and new screen will help much either. Definitely get some more opinions if you decide to go this route.
Good luck, John
Good luck, John
