Heater Core in 87 Wagon?
11 replies to this topic
#1 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 05 November 2004 - 10:28 AM
question: been looking at on-line part sites. have found one place that show the ea81 and ea82's using the same heater core, then found another that showed it changed on 1/87 to a different part.
anybody know for sure? looks like I'll be ripping the dash out for this one...
#2 thealleyboy
thealleyboy
    Subaru Derelict
  • 2,082 posts
  • Bexley, OH
Posted 05 November 2004 - 12:05 PM
I have at least 2 87's (as well as an 86) at home. I never noticed any differences, but I'll check it out tonight.
John
#3 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 05 November 2004 - 11:43 PM
anybody else?
#4 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 06 November 2004 - 06:30 AM
my heater core went bad in my 86 sedan ,i used 1 from a 88 sedan , and it was the right size , also it sure does look like the heater core from a xt4 is the same also
#5 thealleyboy
thealleyboy
    Subaru Derelict
  • 2,082 posts
  • Bexley, OH
Posted 06 November 2004 - 12:34 PM
I inspected all three cores I have, and they are identical. Couldn't find any part #'s though...
Unless my 2 87's were manufactured before 1/87, I would say you are ok. Remember, the inlet/outlet tubes can be modified slightly. The main thing is for the main core to physically fit.
good luck, John
#6 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 07 November 2004 - 01:56 AM
do they look like these?
http://www.ultimates...orecompare1.jpg
#7 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 07 November 2004 - 07:49 AM
yes those are heater cores, be very careful and do not damage the lines , it is a fairly big job
#8 thealleyboy
thealleyboy
    Subaru Derelict
  • 2,082 posts
  • Bexley, OH
Posted 07 November 2004 - 11:03 AM
Those look pretty close but the inlet & outlet pipes are longer (go thru the firewall) on mine. Also the stampings on the core frame on mine are different.
I would say those will work, but you'll have to run heater hoses thru the firewall, and attach them at the core.
good luck, John
#9 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 07 November 2004 - 02:01 PM
yeah, that pic above is from the ea81 heater core swap I did for the USRM. just that the parts store online info shows the ea81 and ea82 to be the same, but I didn't believe them.... just wanted to verify....
thanks,
Mick
#10 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 17 November 2004 - 11:17 AM
man what a pain in the you know what!
I got a core from John, and had it checked out. it's good.
I got the old core out last night. it did not appear that the core had been leaking, but possibly just at the hose connection.... BUT it needed to come out anyway. the top of the core was covered in pine needles, and they were lodged into the fins as well.....
tonight maybe I will start the re-assembly.....
#11 thealleyboy
thealleyboy
    Subaru Derelict
  • 2,082 posts
  • Bexley, OH
Posted 17 November 2004 - 12:11 PM
Those dash's never seem to go back together as nicely as they were assembled at the factory. If you can get it in without any squeaks or rattles, it will be a minor miracle!!
good luck, John
#12 mcbrat
mcbrat
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 17 November 2004 - 01:16 PM
I expect it to go back with lots of rattles, as my method of extraction was far less than "by the book"... it was more of a "unbolt and pull, then see what's still attached" evening :lol:
