ultimate rx, am I screwed?
36 replies to this topic
#1 Guest_subarustyles_*
  • Guests
Posted 18 August 2002 - 08:18 PM
I have almost all the parts for the 5 lug conversion.......I read one of your replies , and do i neet to have the turbo tranny? my wagon is a non turbo
#2 Guest_subyrex_*
  • Guests
Posted 18 August 2002 - 08:20 PM
yeah as you read the splines are different just swap the tranny then do the 5-lug conv. its worth it
#3 Guest_UltimateRX_*
  • Guests
Posted 18 August 2002 - 08:29 PM
Subarustyles, you've got mail.
#4 Guest_subarustyles_*
  • Guests
Posted 18 August 2002 - 08:43 PM
*%&^#@!!!!!!!!!!!! now I need a tranny...........anyone in oregon let me know...............................On a seperate note ...TEACH me the differences between my 4wd hi/lo and the full time...If I make my car full time 4wd, is it going to slow my car down being as I have a week non-turbo(my car is way slower in 4wd)?.....with full time to you get the clicking turning tight radius' like I do when Im in my 4wd?, etc........
#5 Guest_Turbone_*
  • Guests
Posted 18 August 2002 - 09:28 PM
I just so happen to have a 4wd Turbo tranny (push button 4wd). Do you want it?
#6 Guest_PBDLoyale_*
  • Guests
Posted 18 August 2002 - 09:47 PM
Is it four speed? If so I am interested.
#7 Guest_bratsrus1_*
  • Guests
Posted 18 August 2002 - 09:59 PM
Hey Subarustyles This is Jerry, you need to know what gear ratio you have in your car is it a 3.90 or a 3.70. If it 's a 3.70 then Mike or Wapato87 has a rx 5 speed dual range for sale. He lives near Tacoma and i will be there next Saturday pulling a lsd rear end need some help just let me know, i will be there about noon. The rx has the big splines for your axles. Thanks Jerry
#8 Guest_Zak_*
  • Guests
Posted 18 August 2002 - 10:01 PM
It will have more drivetrain loss than FWD, of course, but probably less than you have with yours in 4wd. The problem you describe with tight turns in 4wd is probably due to the fact that you have no center differential, so when in 4wd the front and rear are locked in to the same speed, which isn't good in a tight turn. The full-time 4wd transaxle has a center differential, so you won't have that problem unless you lock it, which you may want to do off road.
#9 Guest_subarustyles_*
  • Guests
Posted 18 August 2002 - 10:20 PM
bratsrus1(Jerry)......mine is a 3.9...If you could give me a call at 541-390-6604(i can call you back, I have free long distance) I would like to discuss the tranny.So I need a new transaxle too? anyway tonight up till 1am,monday late afternoon to all night,or tues between 1&4pm you can get a hold of me...
thanks alot,
bty i'm in bend OR
#10 Guest_Turbone_*
  • Guests
Posted 18 August 2002 - 10:28 PM
PBD, its a 5spd pushbutton 4wd Turbo tranny. Also have the axles, all 25 spline.
#11 Guest_subarustyles_*
  • Guests
Posted 19 August 2002 - 03:33 PM
hey turbone where are you at?
#12 Guest_kelowna kid_*
Guest_kelowna kid_*
  • Guests
Posted 19 August 2002 - 07:15 PM
You should be aware that the turbo D/R tranny doesn`t have nearly as
much gear reduction in low range as the normal one.
(which makes it a poor choice for offroad IMO)
I``ve seen these #s quoted: turbo 1.196 to 1, normal 1.592 to 1
Custom axles may be a better solution to your dilemma.
Why do you want 5 studs anyway? Sounds like a lot of hassle for very
little gain to me.
A centre diff. is also a poor choice for offroad IMO.
(can you say one wheel drive?)
#13 Guest_UltimateRX_*
  • Guests
Posted 19 August 2002 - 08:11 PM
You might be able to get CV Axles to install 23 spline DOJs, it shouldn't be a proplem. He doesn't have any XT6 axle now though, so you would have to send him yours.
#14 Guest_Turbone_*
  • Guests
Posted 20 August 2002 - 02:14 AM
SubauStyles, just look at my Bio.
#15 Guest_UltimateRX_*
  • Guests
Posted 20 August 2002 - 12:27 PM
I called Kevin at CV Axles, he said it wouldn't be a problem. He said it would help if you could fine a 23 spling DOJ with that casing number of 95LAC on it, that is that same casing number of the XT6 4WD DOJ. That way you could keep your tranny and not have to get a turbo tranny, and for $55 apiece, you'll end up with axles with a lifetime guarantee.
#16 Guest_subarustyles_*
  • Guests
Posted 20 August 2002 - 08:41 PM
(This message was left blank)
#17 Guest_subarustyles_*
  • Guests
Posted 20 August 2002 - 08:46 PM
so where can I find the 23 spling DOJ #95LAC...?
...........So do I just send the DOJ's to him, Or do I need to get xt6 axles and send thoose off with the DOJ's( or will he have xt6 axles instock later?)
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :rollin:
#18 Guest_wade12345_*
  • Guests
Posted 20 August 2002 - 10:16 PM
actually the center differential on my subaru works quite well, i broke a cv joint on the front of it, put it in 4 wheel drive and it drove just fine, the differential made you have to take off slow so it didnt slip but it still worked well, and once i was trying to pull a chevy truck out of the mud with it (lets just say the truck was a little to heavy to move) and all 4 tires spun on fiarly hard ground, no 1 wheel drive. I think my subaru is the best car i have ever driven (if i could only keep it on the road for longer then a month without it breaking)
#19 Guest_UltimateRX_*
  • Guests
Posted 21 August 2002 - 06:03 AM
So Wade, did you post this in the right place????
#20 Guest_UltimateRX_*
  • Guests
Posted 21 August 2002 - 06:05 AM
SubaruStyle, lets see if I can explain that better, you will need to send him the XT6 axles AND the 23 spline DOJ, or you can have him purchase a 23 spline DOJ and it will cost more the the normal $55 he charges. Or you can get a set of XT6 axles and a set of axles for a non turbo car and chnage the DOJs yourself.
#21 Guest_bajavwnsoobnut_*
  • Guests
Posted 22 August 2002 - 10:03 PM
hey subarustyle where ya at in oregon I am in portland so email me sometime soon
#22 Guest_subarustyles_*
  • Guests
Posted 24 August 2002 - 03:38 PM
hey Jason, Im in Bend. By the way where do you get other smileys at. like the fish one? :lol:
hey corkey, I know I keep talking about it, but friday I finally got pics with my friends digital camera! soon,soon soon........ ;)
#23 Guest_UltimateRX_*
  • Guests
Posted 24 August 2002 - 08:38 PM
Style, what part of Bend you live it??? Out by Costco?? Up toward Tumalo, or south towards La Pine???
#24 Guest_subarustyles_*
  • Guests
Posted 25 August 2002 - 06:43 PM
I live on the westside, a few miles from downtown..............Do you come here often?
#25 Guest_UltimateRX_*
  • Guests
Posted 26 August 2002 - 06:50 AM
Not often, and even less often lately. I do need to get down there though. So you're on the other side of the river from town. Did that wrecking yard that was out by Costco ever relocate??
