How to Replace starter 1998 my 2.2l
Easy, super easy. I can do it in 20 mins.
If you're looking at the engine facing the vehicle (driver on your right, pass on your left), and the front of the transmission is a clock, the starter is sitting right around 2 o'clock. Once you see it, you can't miss it.
Just pull the wires and remove the bolts (you'll need an extension for the bottom one) and installation is the reverse.
And yes, pull your - battery cable.
  • 2 weeks later...
