anyone know the electrical sys. well?
6 replies to this topic
#1 slideways
slideways
    USMB Regular
  • PipPipPip
  • 34 posts
  • Duluth, MN
Posted 09 November 2004 - 01:13 PM
My gremlin is eluding me. MY turnlamps turn on but do not blink. Can the relay that controls their blinking cause this? Can a short cause this? I'm just trying to narrow this down.
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 09 November 2004 - 01:17 PM
when they turn on, are they kind of dim? Do you hear the clicking from the blinker?
Might be a short, or probably a bad blinker unit. There's a bimetallic strip in there, and that may have worn out.
#3 slideways
slideways
    USMB Regular
  • PipPipPip
  • 34 posts
  • Duluth, MN
Posted 09 November 2004 - 01:27 PM
It is most likely from the deer I hit a couple weeks ago, but I can't find any pinched wires. I've examined the harness all round the front end and I can;t seem to find anything that is stretched or pinched anywhere.
If the blinker unit is bad, do they still illuminate? There is no klicking going on.
What should I look for with a test of the turn signal unit with my multimeter?
All the fuses are fine on the inside fuse panel.
#4 sasquatch
sasquatch
    USMB is life!
  • 230 posts
  • Vancouver
Posted 09 November 2004 - 01:49 PM
first generation Legacy's had the blinker controlled right there with the hazard button no? what kind of car do you have?
#5 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 09 November 2004 - 01:50 PM
blinker relay to test. when they fail they often just light and don't blink.
Warning, you may have caused the relay to fail with a short after the deer crash.
#6 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 09 November 2004 - 01:52 PM
It might be possible that when you hit bambi that you shorted a wire just for a second and killed that blinker relay or a fuse perhaps. Check your fuses and replace the blinker relay. It is under the dash I believe on or near the fusebox. In the old cars they were silver and called flasher relays or mudules. They just plug into the box.
#7 slideways
slideways
    USMB Regular
  • PipPipPip
  • 34 posts
  • Duluth, MN
Posted 09 November 2004 - 02:14 PM
I'll check it out. Its a 93 legacy. When I hit bambi's mom, all of my front lights were smashed so it could have shorted for a brief moment. Thanks for the input.
