ea82 to ea82t conversion???
10 replies to this topic
#1 TotallyCorupt
TotallyCorupt
    USMB Regular
  • PipPipPip
  • 32 posts
  • Gresham
Posted 09 November 2004 - 11:13 PM
i was talking to my buddy who is pretty suby swavy and he said that its alot of work to do the swap from an EA82 to the EA82 turbo motor. he said you have to do the hole wiring harness and all that stuff, well i dont know if he said all that but...i just want to check this out and make sure that its is.
Thanks,
Mike
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 09 November 2004 - 11:14 PM
Motor, exhaust, cross member, wiring harnes.. Bunch of other little random crap.
Not a lot of fun
#3 TotallyCorupt
TotallyCorupt
    USMB Regular
  • PipPipPip
  • 32 posts
  • Gresham
Posted 09 November 2004 - 11:18 PM
why the cross member?
#4 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,151 posts
  • Oregon City
Posted 09 November 2004 - 11:19 PM
so the downpipe coming off of the turbo can clear it
#5 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
  • OMGhi2U in da couve
Posted 10 November 2004 - 12:12 AM
well here's the list..i HIGHLY suggest not doing it...
Motor
COMPLETE engine and dash harness + cpu...don't even try it with a digi gauge turbo
fuel pump
PS hardlines( yes the power steering lines are different between turbo and NA)
cross member
and alot of asprin!!!
#6 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 10 November 2004 - 07:46 AM
It is far easier to find a car that is already turbo'd, there are plenty of EA82T cars out there.
#7 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 10 November 2004 - 11:04 AM
well as far as electronics go.. you could go the do it yersel route and use a meagquirt for the fuel and ignition
but you still have teh crossmembers and such to argue with
#8 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 12 November 2004 - 12:02 AM
think the wiring is pretty easy, you just have it as a stand alone part. all you have to do is power it, ground it, have it controll a relay for the fuel pump, and hookup the trigger wires on the coil, and connect a wire from the computer to the starter solenoid wire. then the rest plugs in like stock to the engine/intake.
thats on the flapper system, i think the hotwiere would be easier, as you wouldnt have to run the trigger wire to the coil.
dash and everything plugs in using your stock wiring from the car, even if its an ea81. i love it! it all fits!
#9 TotallyCorupt
TotallyCorupt
    USMB Regular
  • PipPipPip
  • 32 posts
  • Gresham
Posted 13 November 2004 - 12:04 AM
thanks for the info guys i know now that i am not going to be doing this swap, and ill just look for a EA82T.
#10 bajavwnsoobnut
bajavwnsoobnut
    Insane Rally Freak
  • 3,789 posts
  • Milwaukie
Posted 13 November 2004 - 05:39 AM
another thing to consider is that you have to pass DEQ also (damn vultures again)
#11 AKIRA
AKIRA
    USMB Reverend
  • 618 posts
  • Jersey Shore (Central) PA
Posted 13 November 2004 - 08:30 PM
a legacy conversion would be more worthwile
