Torque settings for front hubs?
4 replies to this topic
#1 Guest_tjdrury_*
  • Guests
Posted 07 May 2002 - 08:28 AM
Hey everyone,
Am I the only new Subie person to be frusterated with the Haynes manual. I can only find half of the info I need about half of the time. Anyway, I can't seem to find the torque spec for the front rotor/hub to spindle nut (big castle nut). It's an '88 GL d/r 4wd. I found the rear but don't want to assume it's the same as the front. Any help would be appreciated, thanks! Toby
#2 Guest_McBrat_*
  • Guests
Posted 07 May 2002 - 09:00 AM
145 ft/lbs.
#3 Guest_NV Zeno_*
Guest_NV Zeno_*
  • Guests
Posted 07 May 2002 - 08:09 PM
Yup, 145....I believe in the Haynes that spec was in the "Brakes" section.;)
#4 Guest_chef tim_*
Guest_chef tim_*
  • Guests
Posted 07 May 2002 - 08:21 PM
FSM says 145+30ยบ, inother words........ as tight as you can!!! :) Tim
#5 Guest_ShawnW_*
  • Guests
Posted 07 May 2002 - 08:25 PM
145 ft-lbs and then find the next hole that lines up on the castle nut (thats my exp for the 30 degrees notation)
