1991 Subaru Legacy won't start!
6 replies to this topic
#1 grdnrofeden
grdnrofeden
    New User
  • Pip
  • 3 posts
  • Reno
Posted 12 November 2004 - 09:01 AM
Hi there I'm hoping someone can help with this problem.
This car has 83000 miles on it and I have never had a problem with it. Check engine light came on sometime ago but my mechanic couldn't determine why.
Then it stalled one day but I was able to get it home-we replaced the fuel filter, crankshaft position sensor, camshaft position sensor and the spark plugs.
Any ideas what else could be wrong?
#2 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 12 November 2004 - 10:06 AM
Please describe the symptoms more. Does it crank over? Is there no spark to plugs? No power at all? Did you attempt to recover codes?
#3 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 12 November 2004 - 10:33 AM
One thing I've learned working on these cars: pull the codes before you randomly start replacing stuff. Just guessing at the problem won't do you any good.
Did you check the alternator and battery? If you suspect you have no spark, also check the coilpack and igniter.
#4 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 12 November 2004 - 12:11 PM
instructions on how to pull the codes is on my website. Pull the codes and post what info you find.
#5 grdnrofeden
grdnrofeden
    New User
  • Pip
  • 3 posts
  • Reno
Posted 12 November 2004 - 05:30 PM
I pulled the codes, and came up with code 11 (crankshaft position sensor). We have replaced the crank, and cam sensors, and it started up right away afterward. as soon as we shut off the engine and tried to start it again it would just crank. Same codes generated (11) We have also replaced the plugs and wires, and I will be checking the coil tonight. It appears to have no spark at the plugs at this time. My thought is it may be the ignitor? or the coil? I know I can check the coil, but am not sure how to test the ignitor if it is good or bad. It seems to follow a pattern, it will (sometimes) start when it is stone cold, but as soon as the engine warms up at all it won't start.
Thanks for your speedy input...
Pulling our hair out here!
#6 grdnrofeden
grdnrofeden
    New User
  • Pip
  • 3 posts
  • Reno
Posted 14 November 2004 - 12:10 PM
Has anyone got any ideas at all? I have not heard anything since I posted a follow up with the detailed symptoms! Could sure use the help here.
Thanks in advance...
#7 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 14 November 2004 - 08:13 PM
If the crank sensor has a problem I don't think you will get get any spark as the ignition system will not function if I remember correctly. I would check the wiring to the sensor for a problem.
