Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Anyone swapped a 5sp. Hi-Lo into older roo...?
#1
Guest_mudrat79_*
Posted 19 July 2000 - 08:11 AM
I horse traded 12 hrs of my labor time for an 86 3 door Turbo . I got the 5 speed Hi-Lo tranny, rear disc brakes, and The very hard to come by Limited slip rear diff....:-))))))))
I pulled all the parts out yesterday, and looking at the tranny, I think it is a bit shorter than the older 4 speed hi-lo...?
I am going to swap all this into my 86 Hatchback, which is shorter anyhow, but they compensate by using a shorter drive line....
Has anyone attemped this tranny swap yet....? I am hoping that the tranny length difference can be remidied by using the 5 speed Duel range ( shorter ) with a full length driveline out of a wagon or something....I know the driveline length difference is about 5-6 inches, and I am thinking the tranny diff is about the same.....I could only get so lucky right....?
If anyone has done this All info is greatly appreciated....I have 3 1/2 weeks before the nekt big 4x4 trip. and I would like to get this all in.....
Then my list of up-grades will look like this
86 Hatchback: 5 speed Hi-Lo , LSD, duel exhaust, Weber carb, Custom bumpers , custom roof rack, rear disc brakes, 3 inch lift........:-)
It WILL be the Ultimate Off-Road Ride......:-)~
Thanks in advance for all info or input, John in Oregon.....
and remember, SEE MUD, MUST PLAY......
#2
Guest_Ross H_*
Posted 19 July 2000 - 09:37 AM
Um, seriously folks, good luck with that project. Lucky for you to get that LSDiff! I bet you'll be able to fit everything together, and then, AS USUAL, all we'll see is your taillights getting further and further and further away...
Can you tell I'm getting worked up for the Wallowa trip? Just getting my smack-talking warmed up!
Again, good luck w/the project!!!
ra
#3
Guest_hodakarider_*
Posted 19 July 2000 - 05:14 PM
By the way, John, your subie sure sounds sweet. My brother lives in Beaverton, maybe next time I'm down to visit him, we could get in touch and talk 'Roo or something. Let me know, as I will probably be down in the next month or two.
#4
Guest_mudrat79_*
Posted 19 July 2000 - 06:44 PM
We are doing a 4 day Camp/4x4/exploring trip August 18-22 this next month....It is a family thing, anyone or thing is welcome.....If you bring an aminal, be able to keep it under control......
Where are you at...? There are going to be a few guys coming to it from the Seattle area...?
Eric Zap, Mike W., and another I think....?
Let me know if you are interested......I have a post on it here on the Board......Look up Wallowa Lake camp trip.....
Later, John Down here in Eugene, Oregon......
#5
Guest_hodakarider_*
Posted 19 July 2000 - 10:36 PM
#6
Guest_byb555_*
Posted 20 July 2000 - 05:32 AM
#7
Guest_McBrat_*
Posted 21 July 2000 - 01:06 AM
scubydoo
Local user
(3/27/00 10:38:08 pm)
Reply | Edit | Del Re: EA-81 5Spd
just 2 weeks ago i replaced the engine in a 86 gl-10 wagon 4x4
sombody (not me) had put a ea-81 in it
it still had the stock 5spd 4x4 dual range tranny in it
obviously whoever did the last engine swap screwed it up because the motor was blown to high heven
anyway,
while i had the engine out i started looking at the clutch\flywheel arrangement
it had:
ea-81 flywheel (8 1/2")
ea-81 pressure plate (8 1/2")
ea-82 clutch disk (8 1/2")
so boys and girls thats how the ea-81 engine to ea-82 tranny setup is done!!!!
enjoy
#8
Guest_hodakarider_*
Posted 21 July 2000 - 01:06 PM
#9
Guest_ShawnW_*
Posted 21 July 2000 - 01:09 PM
SHAWNW
#10
Guest_richierich_*
Posted 22 July 2000 - 09:25 PM
#11
Guest_subeman90_*
Posted 23 July 2000 - 12:28 AM
Matt
#12
Guest_mudrat79_*
Posted 24 July 2000 - 09:18 PM
As to the driveline problem, Here is what I am thinking.
The 5 speed is shorter in length. But My Hatches' driveline is almost 6 inches shorter than the standard cars driveline. What I am hoping is that with the tranny being shorter, I can put a standard driveline in place and make up the difference. Has anyone done or heard of this being done...?
Byb555 where are you....??????
I need info before I get rid of the donator car.....
Later, John in Oregon.....
#13
Guest_byb555_*
Posted 25 July 2000 - 04:49 AM
Ea81 fly wheel (9")
Ea82 clutch plate (9")
Ea82 pressure plate (9")
EA82 throw out bearing
Ea81 starter motor
New tail shaft as per the picture
web.one.net.au/~bybsubi/tailshaft.jpg
I think you should be able to determine what I measured on my vehicle for the tail shaft length. The tail shaft on my car is actually borrowed from a mates Turbo Brat with the 5 spd dual range fitted.
The gear box will bolt straight to the motor, but you will need to muck around with the wiring to get your reverse lights and 4wd lights working. The speedo cable will bolt in. With your vehicles being left hand drive you should be able to get away with the same clutch cable. The EA81 clutch fork is on your passengers side and the EA82 is on the drivers side. (In Oz, we have to change the clutch cable and the pedal box) You may have to do this if thclutch cable does for some unseen reason not fit, so it would pay to pull the pedal box and cable out of the donor car just in case. The pedal box has 4 10mm nuts in behind the pedals and 2 10mm bolts going in an upward direction at the front of the box.
You will need to keep the gear shifter with the 5spd. A small hole has to be drilled for the rear of the shifter to be mounted to the body. This is a simple task when done with the box fitted up and the shift stick poking up through the hole in the floor. It is a matter of pushing the back of the shift up to where it goes, marking the hole and drilling. Probably a good job for your wife as by now you will be looking for a beer and can't be bothered getting back under the car. BTW, get her to do this BEFORE she fits the tail shaft.
I can't seem to think of any thing else at the moment. If I do remember any thing else I will post it.
#14
Guest_redbackroo_*
Posted 25 July 2000 - 06:09 AM
#15
Guest_mudrat79_*
Posted 25 July 2000 - 08:10 AM
My Hatchback has a shorter driveline in it due to the shorter wheelbase....I guess I am going to need to measure the length of the tranny and driveline as a unit, and then measure the 5 speed with a standard driveline attached, and se if my logic is working or not.......
Thanks for the info, and if you do find out it has been done this way, let me know...?
Thanks again, John in Oregon......
#16
Guest_hodakarider_*
Posted 25 July 2000 - 02:01 PM
#17
Guest_hodakarider_*
Posted 25 July 2000 - 02:14 PM
