Guest Subi81 Posted September 12, 1999 Share Posted September 12, 1999 My trip meter has been acting up lately. It won't go past 100 miles. It just stops. Does it just need a shot of lub? Quote Link to comment Share on other sites More sharing options...
Guest ShawnW Posted September 13, 1999 Share Posted September 13, 1999 Does your odometer work okay still? Quote Link to comment Share on other sites More sharing options...
Guest Subi81 Posted September 16, 1999 Share Posted September 16, 1999 Havent really thought about checking that. I will have to check. If it wasn't working that would sugest that the gear in the tranny is broken or the cable istelf could be broken. Thanks for the question. Quote Link to comment Share on other sites More sharing options...
Guest Witte Posted September 16, 1999 Share Posted September 16, 1999 Well when I got mine the trip meter would jam on occasion. to fix it I pusted the reset lots and lots of times. It would jam the main odometer. Quote Link to comment Share on other sites More sharing options...
Guest qman Posted September 16, 1999 Share Posted September 16, 1999 The trip odometer works the same way as the odometer. it runs on two small gears that are run off of the speedometer. So if you are getting to 100 miles but no firther indicates that the gear is probably worn out. I doubt that part is still avail. from subaru so you'll have to disassemble another speedo to get these parts. This should remedy your problem. Good luck! Quote Link to comment Share on other sites More sharing options...
