higgs1 Posted November 22, 2004 Share Posted November 22, 2004 wanted to try the FWD fuse to check the transfer clutch, and couldn't find anywhere that said which fuse to put in? what type of fuse do i use? also to change the differential (front) in my '98 legacy outback do i need to change the whole transmission? Quote Link to comment Share on other sites More sharing options...
coloradosubarules Posted November 22, 2004 Share Posted November 22, 2004 You need a 15amp fuse like you find in your fusebox under the dash. Hope this helps. Quote Link to comment Share on other sites More sharing options...
rweddy Posted November 22, 2004 Share Posted November 22, 2004 wanted to try the FWD fuse to check the transfer clutch, and couldn't find anywhere that said which fuse to put in? what type of fuse do i use? also to change the differential (front) in my '98 legacy outback do i need to change the whole transmission?15ampTo change the differential or the fluid in the differential? Quote Link to comment Share on other sites More sharing options...
higgs1 Posted November 22, 2004 Author Share Posted November 22, 2004 i believe the front diff is bad. it was run with no fluid for a time. i need to swap out the differential, but do i need to swap out the whole tranny? Quote Link to comment Share on other sites More sharing options...
