ramwing7 Posted November 25, 2004 Share Posted November 25, 2004 I have a 1995 Impreza that I suspect needs a new fuel filter(s). Anybody have an idea where it (they) might be and are there any tricks in getting to them? Thanks in advance. Ron Quote Link to comment Share on other sites More sharing options...
frag Posted November 25, 2004 Share Posted November 25, 2004 Just next to the left side (driver's) strut tower. A small cannister with two curved pipes (inlet and outlet) on top of it. Easy to replace if the fuel hoses are not stuck to the filter. Easy method of relieving fuel pressure inside the system: wait three hours, or do it in the morning. In both cases putting a rag or towel around the connection when undoing is less messy. Quote Link to comment Share on other sites More sharing options...
ramwing7 Posted November 25, 2004 Author Share Posted November 25, 2004 Just next to the left side (driver's) strut tower. A small cannister with two curved pipes (inlet and outlet) on top of it. Easy to replace if the fuel hoses are not stuck to the filter. Easy method of relieving fuel pressure inside the system: wait three hours, or do it in the morning. In both cases putting a rag or towel around the connection when undoing is less messy. Many thanks. I'll check it out. Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted November 26, 2004 Share Posted November 26, 2004 http://www.ravensblade-impreza.com/modifications/drivetrain/ffilter/ffilter.html Jamie Quote Link to comment Share on other sites More sharing options...
cookie Posted November 27, 2004 Share Posted November 27, 2004 On my BMW you have to jack it up and get out the jackstands. Then you crawl under and remove the heatshield over the filter. Then you get to have it dribble at you to change it.This is a well done location and is one of those things that make you like the serviceabilty. Quote Link to comment Share on other sites More sharing options...
