Chuck Stills Posted November 25, 2004 Share Posted November 25, 2004 Greetings to all... I have a 2001 Outback LTD Wagon with the dual roofs. The sunshade on the rear roof has somehow become disconnected/malaligned in its track and will not retract with the glass closed. It will however slide back with the glass roof -- like it is somehow attached to the glass. Has anybody else experienced this issue? The Stealership wanted to remove the headliner and disassemble the whole sunroof but there MUST be an easier way. Any comments on this would be appreciated! Chuck 2001 Outback LTD SW 95KM Quote Link to comment Share on other sites More sharing options...
brus brother Posted November 25, 2004 Share Posted November 25, 2004 I had the same issue with my 2000 Legacy GT. From the outside, open the door and stand on the doorsill with the moonroof open so you can see what's going on. In my case, the back moonroof shade had jumped the track similar to what you describe where the window would drag it back when opening the window. Examine both sides and you should be able to determine which one rides smoothly in the track and then try and gently reposition the misguided side. Then run around the yard yelling TADA! There is a Technical Service Bulletin: http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm Make : SUBARU Model : LEGACY Year : 2000 Manufacturer : SUBARU OF AMERICA, INC. Service Bulletin Num : 128003 Date of Bulletin: MAY 19, 2003 NHTSA Item Number: 10001727 Component: VISIBILITY:SUN ROOF ASSEMBLY Summary: SUNSHADE FOR REAR SUNROOF ON DUAL SUNROOF MODELS. The following website is specific to your car's TSBs but doesn't mention this condition. Check out the other issues. These are not NHTSA safety recalls but rather SOA heads up bulletins for their dealerships. http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm It's easy finding your way when you know where you are going! Quote Link to comment Share on other sites More sharing options...
Chuck Stills Posted November 30, 2004 Author Share Posted November 30, 2004 Thanks, bus brother... Once the rain finally stopped and I could spend some time fiddling with it, I managed to get it aligned and sliding again. The wife didn't really appreaciate my "TADA" when demonstrating the fix... at least I didn't run around the yard, then she may have thought I'd really gone off the deep end. Thanks again for your note. -Chuck- I had the same issue with my 2000 Legacy GT. From the outside, open the door and stand on the doorsill with the moonroof open so you can see what's going on. In my case, the back moonroof shade had jumped the track similar to what you describe where the window would drag it back when opening the window. Examine both sides and you should be able to determine which one rides smoothly in the track and then try and gently reposition the misguided side. Then run around the yard yelling TADA!There is a Technical Service Bulletin: http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm Make : SUBARU Model : LEGACY Year : 2000 Manufacturer : SUBARU OF AMERICA, INC. Service Bulletin Num : 128003 Date of Bulletin: MAY 19, 2003 NHTSA Item Number: 10001727 Component: VISIBILITY:SUN ROOF ASSEMBLY Summary: SUNSHADE FOR REAR SUNROOF ON DUAL SUNROOF MODELS. The following website is specific to your car's TSBs but doesn't mention this condition. Check out the other issues. These are not NHTSA safety recalls but rather SOA heads up bulletins for their dealerships. http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm It's easy finding your way when you know where you are going! Quote Link to comment Share on other sites More sharing options...
brus brother Posted November 30, 2004 Share Posted November 30, 2004 The wife didn't really appreaciate my "TADA" when demonstrating the fix... Doesn't she understand that items completed on the "To Do" list are immediately transferred to the "Ta Da" column? Quote Link to comment Share on other sites More sharing options...
