Guest offroadsubaruguy Posted August 7, 2003 Share Posted August 7, 2003 ok, heres the scoop..... my tach has been jumpy lately, my idle is super rough, and i have almost no bottom end power, and on top of that, i occasionaly have some pretty bad hesitation..... now, i have heard that the jumpy tach is a sign of a bad disty, but could a bad disty also be causing my other problems???? any info will help, and i just noticed the jumpy tach a little less than a week ago, everything else has been around for a while...... thanks for your imput !!!! Quote Link to comment Share on other sites More sharing options...
Guest Cougar4 Posted August 7, 2003 Share Posted August 7, 2003 From the sounds of your post you may be correct. I think there is a transistor in the circuit also that acts as a switch and it may be that also. Glen Quote Link to comment Share on other sites More sharing options...
Guest GeneralDisorder Posted August 7, 2003 Share Posted August 7, 2003 Have the shaft re-bushed. Cost is about $30. Should fix many of your problems. They will start to run bad before the tach starts jumping - loss of power - everything you describe. The electronics are working if the engine is running. There should be NO play in the shaft when you check it - if there is any at all noticeable, it's bad. Mine was horrible (tach was jumping to 7000 and staying there !!), but I could just barely tell the shaft was loose. Doesn't take much to throw the timing WAY off. GD Quote Link to comment Share on other sites More sharing options...
Guest offroadsubaruguy Posted August 8, 2003 Share Posted August 8, 2003 what do i do to get it re bushed? where can i take it? what does it do? and thanks for the info guys!!! Quote Link to comment Share on other sites More sharing options...
Guest edrach Posted August 8, 2003 Share Posted August 8, 2003 Make sure all your ignition wires are properly connected also. As to rebuilding your distributor: <a href="http://www.philbingroup.com/rebuilt/special_services.htm" target="top">http://www.philbingroup.com/rebuilt/special_services.htm</a> Quote Link to comment Share on other sites More sharing options...
