Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
over heating bearings
#26
Posted 21 August 2003 - 10:54 AM
I can't imagine throughly packing them when they are installed.
The classic method of hand-packing is to put a dob of grease on the palm of your hand. Stick a finger, or 2, through the bearing and gently slap one edge of the bearing into the grease. Repeat until grease squishs out the other side of the race. Turn the bearing a little and repeat until the entire race has grease coming out from the other(top) side.
There are also cheap bearing greasers that connect to a grease gun.
Possibly you have a bad bearing?
The heat could be coming from somewhere else.
Do the brakes drag or pull?
What about the CV joint, is it good?
Try switching hubs/disc from side to side.
You may just have to drive it till it becomes obvious what the problem is.
#27
Posted 21 August 2003 - 11:34 AM
#28
Posted 21 August 2003 - 10:53 PM
I can't see how the hubs could make a difference.
Try swapping them from side to side.
A period every now and then would be nice, also.
#29
Posted 22 August 2003 - 07:19 AM
#30
Posted 22 August 2003 - 08:20 AM
I recommend you take them out and start over.
Put the suspect bearings on the other side this time and see what happens.
Good luck and let us know the results!
#31
Posted 22 August 2003 - 08:28 AM
#32
Posted 22 August 2003 - 11:08 AM
#33
Posted 25 August 2003 - 10:39 AM
#34
Posted 25 August 2003 - 01:39 PM
#35
Posted 25 August 2003 - 03:54 PM
#36
Posted 26 August 2003 - 11:00 AM
As I said in the reply to your email. You do have the spacer in between the bearings...correct?? Don't "Overtorque" the axle nut!
I'd repack the bearings more, but it sounds like classic brake drag. Make sure your EMR brake is adjusted correctly too. You can do this from the interior lever.
Todd
http://m2.aol.com/subaru3
subaru3@aol.com
#37
Posted 26 August 2003 - 11:21 AM
#38
Posted 26 August 2003 - 12:43 PM
#39
Posted 26 August 2003 - 04:58 PM
the bearings was spinning with the race i think i fix them for now
but when i got home the hub was very hot again:banghead:
#40
Posted 26 August 2003 - 05:30 PM
The bearings do not go in the *hub*. They go into the steering knuckle from the engine side. The cv axles must be removed to get at them.
The *hub* is what the lugs go through and the brake disc attaches to and must be removed from the outside.
Are you saying the bearing race is spinning in the steering knuckle?
Did you swap the hub and/or bearings from side to side?
Coincidently, the book calls for 145FtLbs on the axle nut. I don't think you can over-torque it, it'll strip first.
#41
Posted 26 August 2003 - 06:14 PM
#42
Posted 01 September 2003 - 11:51 AM
