86subaru Posted December 1, 2004 Share Posted December 1, 2004 i am thinking about buying a 1994 awd a/t wagon w/ 142,000mi , real clean, no rust , no dents, light blue, it needs a passanger side drive axle, other than that seems good, but iam not sure of the timming belts or belt, is there just 1 timming belt? how long do they last ? is there anything else that is common problem ? working on them is just as easy as a ea82 motors ? how about mpg ? the used car lot wants 2200 bucks , but of course talk him down like 1900 Quote Link to comment Share on other sites More sharing options...
rweddy Posted December 1, 2004 Share Posted December 1, 2004 is there just 1 timming belt? Yes how long do they last ? Timming belts? 60k engine - usually good for 300+ is there anything else that is common problem ? Nope working on them is just as easy as a ea82 motors ? I think they are easier plus way more power, no oil pump leak issues, etc. how about mpg ? I got 28-30 with my 91 AWD 5spd wagon Quote Link to comment Share on other sites More sharing options...
86subaru Posted December 1, 2004 Author Share Posted December 1, 2004 thanks Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted December 1, 2004 Share Posted December 1, 2004 RUN! Any used car lot that sells a car with a known defect (even if disclosed) rather than repairing same is NOT to be trusted. Unless it's a back row 'mechanics special' for a few hundred, not a car advertised at over two thousand. Keep looking, there are lots of GOOD Subarus out there. Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted December 1, 2004 Share Posted December 1, 2004 Just have someone you trust look over it...i got an impreza with almost 300k on it and it runs like a dream with no leaks or signs of dying...but be sure before you buy...timing belts are good to change...but are not devestating on 90 ish model subarus....like hondas or such Hope this helps Quote Link to comment Share on other sites More sharing options...
86subaru Posted December 2, 2004 Author Share Posted December 2, 2004 well found another awd a/t legacy L wagon, 213,000mi , new tires, new timming belt, brakes all done, oil leak fixed, new fan belt, , some rust on both fenders, alittle rust on the back , only thing i could see it needed was an exhaust from the cat back, ac needed recharged , owner says the dealer put a new headgasket on, what size of pipe should i use if i buy it from the cat back to the muffler ? he wants 1500 bucks ,but i think i could get it for 1200-1300 , all the above work was done 2,000 miles ago , thanks Quote Link to comment Share on other sites More sharing options...
86subaru Posted December 3, 2004 Author Share Posted December 3, 2004 bump... Quote Link to comment Share on other sites More sharing options...
