Code 42 in the leggy..WTF?
11 replies to this topic
#1 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 01 December 2004 - 07:21 PM
I just replaced the O2 sensor in my 90 legacy wagon and it is running pretty good but now it is giving me the 42 code. WTF! What is it and what does it do? How do I fix it? What will it do or not do untill I can fix it?
Thanks everyone for looking. I appreciate everyones input. Even if it is to say I am SOL!
What does the Subaru God (Josh) have to say?
#2 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 01 December 2004 - 11:54 PM
somebody....anybody. Come on all you subasmarties...
#3 Gnuman
Gnuman
    1000+ Super USER!
  • 1,399 posts
  • Richmond, CA
Posted 02 December 2004 - 12:31 AM
42: Idle switch, Abnormal voltage input entered from idle switch.
Fail safe is to Judge OFF operation.
That is from Legacy777's page, BTW. . .
From that I would guess that you have a bad idle switch. Is the car idling badly?
#4 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 02 December 2004 - 12:39 AM
I know what the code was for...
Car idles a tad rough but when it warms up it is fine. Should I replace it or skip it?
Is there anything besides the O2 sensor that would make it run rich? Still kinda stinky.
#5 Gnuman
Gnuman
    1000+ Super USER!
  • 1,399 posts
  • Richmond, CA
Posted 02 December 2004 - 12:46 AM
I'd clear the code first, and then see if it returns. If it does, then replace the switch. I dunno the cost of the switch though. . .
#6 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 02 December 2004 - 02:10 AM
Here's my yet-to-fail fix for that code.
Swap throttle bodies. Pull one from a junkyard. I have swapped throttle bodies on my car to have one that still has its factory settings (I played with stopscrews when I was younger :-\ ). Then I did the same with a coworker's 92 Legacy who had the same code. Problem fixed.
The idle switch is built into the TPS, which is on the passenger side of the throttle body. The TPS is set from the factory in a certain position, you can see the white marks on the screws. It's best not to mess with that, so if you just swap the whole thing, you won't have that problem.
#7 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 02 December 2004 - 11:26 AM
Thanks for the tip. I try to find a legy with low miles so I can pull the TB..maybe I will take the entire engine and tranny. My tranny is sucking...
Thanks guys. I knew I could count on you. See you in Jan.
#8 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 03 December 2004 - 12:27 PM
Test the idle switch in the TPS.
Follow this procedure
http://www.main.expe...PS_testing3.jpg
Here's the preceeding info, which tells you which pins are which
http://www.main.expe...PS_testing1.jpg
http://www.main.expe...PS_testing2.jpg
If it's out of spec, adjust it so the readings are in spec, clear the codes, and see if you still get the code.
#9 vrg3
vrg3
    USMB Regular
  • PipPipPip
  • 36 posts
  • Ithaca, NY at times and McLean, VA at other times
Posted 03 December 2004 - 09:30 PM
Even if those tests check out, you still might try subyluvr2212's suggestion. In my experience, the idle switch code is sometimes thrown when there's an inappropriate load on the TPS power supply, and that can be caused by something weird in the TPS.
#10 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 03 December 2004 - 10:19 PM
Thanks Josh for the info. I think I am going to just replace the throttle. Maybe someone makes a bigger throttle body????
Anybody have any suggestions as to where I can find a bigger throttle body? Perhaps the WRX has a biggger one?
Hmmmm...
#11 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 04 December 2004 - 05:38 PM
If you want a bigger TB....bore it.....the newer ones aren't any bigger and won't work with your car. However I wouldn't bother boring it.....it's one of the last bottlenecks.
#12 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 04 December 2004 - 06:28 PM
How bore'ing...LOL. I wonder if it hasbeen done?
