Are your thermometer readings REAL SLOW to react to temp changes?
(by the way, Altimeter seems overly sensitive)
I can drive all the way to work with the thermometer heat sensor in side the car with the heater on (extra crispy setting) and it still never changes
I've had it in about a week and I've only seen it change two degrees while I'm driving?
However when I leave the car over night the sensor will eventually sence the temp and display the correct temp when I start the car in the morning. The problem is it will display that temp for most of the next day. It wil have changed a little by the time I'm ready to drive home.
Why is this so slow to react to temp changes?
I've checked to make sure it's pluged in properly, if it's not it displays an error message.
Confused
Glenn,
82 SubaruHummer--always the same temp inside as outside
01 Forester--displays the same temp inside as outside
****I'm not talking about the built in one in the inst cluster**** that works fine!
