I have a 92 legacy turbo with a long term problem. It only happens sometimes but has been quite frequent lately. When starting to accelerate from a period at low revs, it stutters /coughs /missfires /doesn't run properly until it gets a good burst from the accelerator. Then it seems OK again. My feeling is that it is a fuel mixture problem. I have replaced spark plugs and filters. Also have tried another MAF sensor. Could it be the igniter or the throttle position sensor? What about a fuel pressure problem? How can I check these?
generally the car always starts well. Sometimes the idle can be a bit variable.
Occasionally, if I run the self check on the computer it will come up with an error code for the knock sensor. Could this be related to the problem (the problem occurs much more often than the code comes up (which might be every couple of months)) or is it more likely to be a misfire from bad petrol?
Thanks for your help
John
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
legacy intermitent drivability problem
Started by
johnfmcewan
, Dec 04 2004 05:43 AM
1 reply to this topic
