Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Oh boy, more codes, help!
#1
Posted 06 December 2004 - 06:41 PM
A couple of weeks ago now the CEL came on. The codes 24 and 35 appeared.
From what I understood it was probably the fuel purge solenoid. I didn't replace it since it would only come on once and a while.
Two days ago the CEL came on again, and it won't go away. I still wasn't too concerned, I was going to replace the solenoid this week or next and see if that solved the problem. If it didn't then I would look into replacing the air control valve.
When I start the car when the engine is cold the rpm only rise to about 800-1000. There is a fairly strong smell of gas from the exhaust when the car is first started. Once the engine warms up it idles at 1200-1300 rpm, it will occassionally blip up and down betwenn 1200-1250 rpm. Then sometimes it idles around 2000 rpm then will quickly fall back down to 1200 rpm. The exhaust seems to be louder as well, not like a hole in the exhaust, but just louder. The car seems to drive OK when the rpms are kept higher than 2500 rpm. The mileage doen't seem to be affected too much.
Like I said this didn't concern me too much until I decided to pull the codes up tonight for some reason. The codes 11, 12, 24, 32, 35 appeared. These would be Crank Angle Sensor, Starter Switch, Air control valve, Oxygen sensor, Canister purge solenoid. I truly hope all this doesn't need replacing. Any light on this situation would be greatly appreciated. Thanks in advance!
#2
Posted 06 December 2004 - 07:45 PM
I apologize for all the typing errors I made on this and all posts. I just got my new laptop and the keys seem to be closer to eash other and they are still a little stiff.
#3
Posted 06 December 2004 - 09:34 PM
#4
Posted 07 December 2004 - 11:51 AM
Few questions
1. The person I bought the car off of has a loyale....I think(could be a legacy, didn't take a close look, he said most of the parts would fit.). Would the parts off of this car fit if it is a 2.2L?
2. While I was checking all the hoses I noticed a black rubber square like piece that seems to be on the transmission. It is almost directly below the throttle body. Anyways it wasn't sitting in place correctly. what is it? Could this cause damage to the car?
#5
Posted 07 December 2004 - 12:17 PM
Can you take a pic of the piece in question?
Or possibly look through some of these pictures I took of my injector work and identify it
http://www.main.expe...mages/injectors
#6
Posted 07 December 2004 - 12:53 PM
#7
Posted 07 December 2004 - 04:38 PM
http://www.main.expe...rs/DCP_2488.JPG
It's just a cover....nothing to worry about.
#8
Posted 07 December 2004 - 06:59 PM
#9
Posted 07 December 2004 - 09:25 PM
try this
https://www.mail.exp...rs/DCP_2488.JPG
#10
Posted 08 December 2004 - 06:05 AM
So would any 1990-1994 legacy do for parts? Does this include the turbo? Re:the air control valve and purge solenoid.
#11
Posted 08 December 2004 - 12:42 PM
#12
Posted 08 December 2004 - 07:39 PM
I'm pretty sure it is the air control valve that is causing the majority of the problems and not the fuel purge solenoid. I hooked the fuel canister directly to the throttle body, this made no difference in how the car behaved. I've read about people spraying brake cleaner into the air control valve, there are a lot of mixed reviews here. I think I might spray a little cleaner into the valve. Good idea?
Wow you know a lot about the legacy Josh.
Thanks for all your time
#13
Posted 09 December 2004 - 09:15 AM
I've done the brake cleaner thing on the IAC valve. I did it a while back when I had taken everything off. It did seem to help.
Might want to give it a shot and see. However if the code is being displayed for the IAC valve, more then likely there's some sort of electrical issue with it, and cleaning prob. won't do anything.
#14
Posted 10 December 2004 - 01:57 PM
Here is my reasoning:
When the car starts to act up the codes 24 and 35 appear. When I hooked the fuel canister directly to the throttle body there was no change in how the car behaved. The 2 codes still appeared obviously, since the purge solenoid was not connected. I cleared the codes, hooked everything back up and started the car, everything was normal. I was getting the all clear signal from the car. I drove the car, shut it off then restarted it, started to act up again. Retrieved the codes, it came up 24 and 35 again. It is hard to believe that both sensors would work and fail at the same time if they were not cannected somehow. Probably not that useful, but, maybe it will help somebody somehow,
#15
Posted 11 December 2004 - 10:40 AM
I'd still suggest replacing the canister purge solenoid, and go from there.
#16
Posted 12 December 2004 - 12:31 AM
Thanks again Brent
