Loosening Camshaft sprockets bolts - timing belt on or off?
To loosen camshaft sprockets, should I first remove the timing belt? Or do it with timing belt in place ?
Otherskips page
http://mysite.verizon.net/vze730qe/Head_gasket_replacement_2.html
suggests doing it BEFORE removing timing belt. The subaru service manual suggests removing/loosenig the bolts after.
The only reason I can see leaving it in place would be that if camshaft ends up rotating counter clockwise a little bit, both intake and exhaust would rotate counter clock wise together. If both intake and exhaust rotate counter clockwise together, does it create interference on valves?
What if you remove timing belt and them do it? I guess independent rotation could still create problem...
Balu
Engine is out of car for blown head gasket.
I can still wedge the flywheel with a couple of screw drivers. Some said, don't put too much tension on timing belt (I guess this would) - I am planning throwing away the old timing belt anyway...I might try what you suggested.
  • 4 weeks later...
