WJM Posted December 12, 2004 Share Posted December 12, 2004 First...I need an N/A daily driver. Such as a 3AT 2wd or 4WD SPFI EA82 kaa with CRUISE CONTROL. Or that pristine condition 3 door coupe I found thats 2wd 5 speed. Next goal: RX=Fast. Koni double adjustable coilovers Replace all the rubber bushings with Delrin (sp?) Re-work the engine if it blows before sept 2005 (pistons, rods, ARP studs, Cometic HG, Peaco crank, spyder, TB) MS+DIS, installed and tuned in properly TD04-13G (deadbolted hopefully) USDM STi TMIC with 04 spec hood scoop Roll bar and two harnesses WRX or STi or other seats New front camber plates...possibly my special offset solid bushing for the lower control arms Possibly a new steering wheel...MOMO knock off type stuff Fix shift linkages Tranny (if funds are present): STi RA gear set Reinforced everything Special syncros Cusco front/rear diffs Cusco 35/65 planetary center diff Rework the shift forks/rods *CAR MUST REMAIN SCCA SOLO2 STREET MOD LEGAL!!!!* (that means no crazy BS... ) more to come.... Goal is to get the car/driver up to the speed level of a certin 05 ESP flat 4 kaa....and to piss off Scott Segal as he's an asshat. Oh, and to be the fastArest RX evAr. Quote Link to comment Share on other sites More sharing options...
Vanislru Posted December 12, 2004 Share Posted December 12, 2004 Wow, can you spot a guy some cash too? Quote Link to comment Share on other sites More sharing options...
WJM Posted December 12, 2004 Author Share Posted December 12, 2004 No. I need all I can get. Quote Link to comment Share on other sites More sharing options...
Vanislru Posted December 12, 2004 Share Posted December 12, 2004 No. I need all I can get. Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted December 12, 2004 Share Posted December 12, 2004 Goal is to get the car/driver up to the speed level of a certin 05 ESP flat 4 kaa....and to piss off Scott Segal as he's an asshat. Oh, and to be the fastArest RX evAr. Who's that? He doesn't happen to have a brother name Steven does he? And when are you getting on the dyno again? Quote Link to comment Share on other sites More sharing options...
sportsterbrat Posted December 12, 2004 Share Posted December 12, 2004 How long would that daily driver stay stock? Quote Link to comment Share on other sites More sharing options...
WJM Posted December 12, 2004 Author Share Posted December 12, 2004 Who's that? He doesn't happen to have a brother name Steven does he? And when are you getting on the dyno again? I dont know if scott has a bro. Dyno? as soon as Top Speed here in atlanta gets thier dyno up and running. Dyno jet, in ground...can handle 1800 HP! Porter will give me t3h hook up! Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 14, 2004 Share Posted December 14, 2004 Oh, and to be the fastArest RX evAr. Not unless I beat ya to it.......workin on producing another motor once I get the JDM motor bought, to the house, and in my car......mwahahahahahaa:D:D Then get a set of gen 3 heads and have them WORKED like none other. I'm liking the sound of bigger valves, lots of porting, a nice set of cams, titanium valve springs for those 9k rpm shifts, full hyperutectic bottom end including lightened crank and aluminum rods. Plus a set of .030 overbored carbed pistons to top everything off with. Oh and maybe a EJ intake setup if I feel like massaging it to work on there:D Now I need to find someone with a metal shop so I can start working on machining everything I'll need....MWAHAHAHAHAHAHAHA Quote Link to comment Share on other sites More sharing options...
MorganM Posted December 14, 2004 Share Posted December 14, 2004 Your first goal for the year should be securing the funding to build it... Quote Link to comment Share on other sites More sharing options...
WJM Posted December 14, 2004 Author Share Posted December 14, 2004 Your first goal for the year should be securing the funding to build it... Win lotto! Quote Link to comment Share on other sites More sharing options...
MorganM Posted December 14, 2004 Share Posted December 14, 2004 Win lotto! Keep dreaming then Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 15, 2004 Share Posted December 15, 2004 get job at Wal-Mart. Make bank shortly after.....w00t!!! I had a good evaluation for my 90 days I've been there and I'm getting a $.40 payraise on the 13th of January!!! So then I'll be making $7.60 an hour...and I've only been there a couple months;) Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted December 15, 2004 Share Posted December 15, 2004 I'd rather just sit around collect some welfare and wait for "Ed" to come knock at my door with his homies (the prize patrol). Quote Link to comment Share on other sites More sharing options...
WJM Posted December 15, 2004 Author Share Posted December 15, 2004 ijm working at prestige suby now...so i get more than foglers...so after bills are paid from not working...watch out SM! Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted December 15, 2004 Share Posted December 15, 2004 Oh, and to be the fastArest RX evAr. Not so fast Will! Ah B Teh Cheata--> J/K Quote Link to comment Share on other sites More sharing options...
WJM Posted December 15, 2004 Author Share Posted December 15, 2004 that stuff is not legal at SCCA events. :-p Quote Link to comment Share on other sites More sharing options...
