forester&forester Posted December 17, 2004 Share Posted December 17, 2004 I REALLY NEED HELP ON THIS ONE. LOTS OF QUESTION MARKS FLYING OVER MY HEAD. FORESTER TEMP JUMPS UP TO ALMOST RED AT HIGH RPM ( OVER 4000 ) IT GOES UP IN TWO SECONDS AND THAN BACK DOWN JUST ABOUT IMMEDIATELY ? IN THE PROCESS IT THROWS SOME COOLANT OUT BUT OTHERWISE ENGINE RUNS GREAT. NOW THE MYSTERY HEAD GASKET ? WELL I HADE THE SAME IDEA AND THE SPARE ENGINE SO I DID REPLACE THE ENGINE.GUESS WHAT,SAME THING IS HAPPENING WITH DIFFERENT MOTOR WITCH IS GOOD FOR SURE.THEN I REPLACED RADIATOR AND THE CAP.PROBLEM IS STILL THERE. ONLY THING I HAVEN'T TOUCHED SO FAR IS THE THERMOSTAT BUT I REPLACED THE ENGINE REMEMBER ANY IDEAS WOULD BE HIGHLY APPRECIATED AS I HAVE RUN OUT Quote Link to comment Share on other sites More sharing options...
coloradosubarules Posted December 17, 2004 Share Posted December 17, 2004 Did you burp the cooling system? I mean really burp it.... Filling the cooling system is fine and dandy but it needs to be 100% air free. Quote Link to comment Share on other sites More sharing options...
forester&forester Posted December 17, 2004 Author Share Posted December 17, 2004 Did you burp the cooling system? I mean really burp it.... Filling the cooling system is fine and dandy but it needs to be 100% air free. OVER AND OVER AGAIN. HAVE GOOD HEAT Quote Link to comment Share on other sites More sharing options...
outback_97 Posted December 17, 2004 Share Posted December 17, 2004 It might be beneficial to know the year and engine (Phase 1 or Phase 2) and PLEASE DO NOT WRITE IN ALL CAPS!! It means you're shouting when you write in all caps FYI. Thank you. Steve Quote Link to comment Share on other sites More sharing options...
coloradosubarules Posted December 17, 2004 Share Posted December 17, 2004 New Subaru T-stat installed the correct way? Quote Link to comment Share on other sites More sharing options...
Setright Posted December 17, 2004 Share Posted December 17, 2004 Search for "coolant replacement". I did a thread on a sure-fire way to avoid air pockets. Also, you might want to remove and flush your radiator. Quote Link to comment Share on other sites More sharing options...
