bearbalu Posted December 18, 2004 Share Posted December 18, 2004 I am doing head gasket. Does anyone know if I should redo the half moons that are on the back side (towards flywheel) of the head. If so what sealant should I use? Permatex Ultra grey okay. Subaru Service Manual doesn't mention it all all in Cyclinder Head service procedure. Quote Link to comment Share on other sites More sharing options...
richierich Posted December 18, 2004 Share Posted December 18, 2004 yes, you should but you should put in new half moons, rather than trying to reseal those in. If you can't get them or don't want to do it, it is better to leave them alone, than take them out and reseal the oil ones. Grey High Temp Permatex will work. Also put a dab of it where the camshaft seal housing and the valve cover gasket touch. (There should be little bit of it dried up there, so clean that off and then add somemore. Quote Link to comment Share on other sites More sharing options...
99obw Posted December 19, 2004 Share Posted December 19, 2004 IIRC mine were in so tight that I couldn't easily get them out, so I left them alone. The sealant used at the factory seems really good. No leaks so far. Quote Link to comment Share on other sites More sharing options...
bearbalu Posted December 19, 2004 Author Share Posted December 19, 2004 I do have new half moons...I will see if I can pull them out...if not I will leave them alone... thanks Quote Link to comment Share on other sites More sharing options...
richierich Posted December 20, 2004 Share Posted December 20, 2004 If they don't come out, put a little silicon over them before putting the valve cover back on. Quote Link to comment Share on other sites More sharing options...
bearbalu Posted January 2, 2005 Author Share Posted January 2, 2005 I sprayed some permatex gasket remover and they pulled off real easy. Put in the new ones. Does anyone know what function the half-moons serve? Why not just have metal there instead? Quote Link to comment Share on other sites More sharing options...
99obw Posted January 2, 2005 Share Posted January 2, 2005 I think those are the result of line boring the heads for the cam journals. Quote Link to comment Share on other sites More sharing options...
