WJM Posted December 24, 2004 Share Posted December 24, 2004 Maybe...???? Ofcourse....the impreza/legacy hub would need to be used on the front... Quote Link to comment Share on other sites More sharing options...
BobBrumby Posted December 25, 2004 Share Posted December 25, 2004 ooo their sooo shinny Quote Link to comment Share on other sites More sharing options...
subyrally Posted December 25, 2004 Share Posted December 25, 2004 ooowowwwwwwyy, my wallet hurts. just looking at those Quote Link to comment Share on other sites More sharing options...
JWX Posted December 25, 2004 Share Posted December 25, 2004 where'd you find those? the rears look like they might bolt up to the front of EA81 cars. the top mount anyways Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted December 25, 2004 Share Posted December 25, 2004 Bolt them bad boys up and do a complete installation write up on it. Quote Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted December 26, 2004 Share Posted December 26, 2004 The rears are stupid easy to do. Those rears will not actually work. What i'm using on my rally car is basically an off the shelf Bilstien Shock with threaded body. We then had custom stainless steel pin mounts for the tops made. They need to be 12 MM in diameter to bolt into the top mounts in the rear. The bottom we are using a 1/2 inch Spherical bearing, so we reemed out the Rear mounting holes to accept 1/2 Bolts. The front...yes basically anything from a Legacy/impreza will work if you do the XT6 hub swap. The problem you will run into is, that an impreza or Legacy is for all intentsive purposes a 3000 lb car. These RX's and crap are somewhere between 2500-2600 lbs. That's a big difference....not to mention the Impreza/Legacy stuff is designed to support in most cases a big ole 2.5 motor.....or the 2.0 Liter turbo. Both of which are heavier than the 1.8...much heavier as a matter of a fact. My front struts. Custom 4130 Chromoly Strut tubes, with Bilstien rally inserts are of the inverted design like these Zeals, and go right into the Stock (4 cylinder) front hubs. and bolt into the stock top mounts. Quote Link to comment Share on other sites More sharing options...
JWX Posted December 27, 2004 Share Posted December 27, 2004 do you have pics of this setup? I'd love to see it. I bet some camber plates would help you Quote Link to comment Share on other sites More sharing options...
WJM Posted December 27, 2004 Author Share Posted December 27, 2004 what you posted Pics!!!!!! Quote Link to comment Share on other sites More sharing options...
GLCraig Posted December 27, 2004 Share Posted December 27, 2004 how about Part #s for the off the shelf rears, please? Quote Link to comment Share on other sites More sharing options...
Do It Sidewayz Posted December 27, 2004 Share Posted December 27, 2004 Gimme a few days to Drag the Rally car back down here. and i'll take a pile of pics. I'm sure you guys will love everything about it...it's got like a zillion point roll cage....bilstien coil-overs....lotsa crap. Quote Link to comment Share on other sites More sharing options...
JWX Posted December 27, 2004 Share Posted December 27, 2004 yes pics we need pics Quote Link to comment Share on other sites More sharing options...
