Carb adjustment
1 reply to this topic
#1 Guest_ProphetM_*
  • Guests
Posted 22 July 2003 - 03:48 PM
I finally got a new carb on my Justy. They had to order one from Japan. Anyway, I didn't make any mixture adjustments and I don't know if I should or not. Currently it's idling a little higher (1400) than it should (900), but when idling down where it should it's a little rough. I'm wondering what this might indicate. There's a bit of hesitation from a stop when it's cold, too. My mileage could be a little better so my first guess is that it might be running a bit rich. Is the kind of stuff I described indicative of that, or of something else in particular?
In any case, I am glad to finally have on there a carb that seems to be working properly, rather than the two crap reman'd ones that were on there before.
#2 Guest_brokechump_*
  • Guests
Posted 07 August 2003 - 11:39 AM
Sounds like the same thing I'm going through...81 EA81 GL wagon with a rebuilt hitachi. I got my idle down by playing with the mixture and timing. The timing might help it idle a little smoother down low. Mine hesistates horribly when cold, but once at operating temp for 5 minutes it runs great. Hesitation can be caused my a malfunctioning EGR valve and/or vacuum leaks in my experience. Just my 2 cents...I'm still trying to figure out my hesitation.
