ea-81 coolant system Q
Well - the system is under pressure, so when you release pressure (assuming the system is hot), the the coolant will tend to boil. That could be the source of some of your bubbles. Either that, or the system is pulling in air from somewhere, and it's comming up to the radiator. You sure you have all the air bubbles out of your heater core?
