diff
85 Gl
my diff in me 85 gl 4wd d/r looks like it has a locked diff in the rear when i turn on the drive way i can hear it jumping on the innner wheel that i am turning i put one side on the jack and put it in 4wd and i could only turn the wheel a few inches then it would start driving the other side, so do these have locked diff
yep i no about the jack the entire rear off the ground and if the opposite wheel spins its lsd ill check the tag now
k i checked the tag didnt say lsd on the tag the gear ratio was 3.9 so im guessing it is a lsd, i just dont think it is tho because ive never seen a lsd work like that my bro has a ford with lsd in the rear and it doesnt do that the diff in the suby is working more like a diff lock
you should go back and read Qman's post more closely.
You have an open rear diff but a locked center diff
this is what is causing the jumping,
NOT the rear diff.
You brothers truck no doubt has an open center differential.
NOT the rear diff.
o ok thanks for clearing that up:)
i also lifted the rear up and yea the other wheel spun the opposite way to wat i was spinnning the other way, thanks guys yet again:)
