DDad Posted January 1, 2005 Share Posted January 1, 2005 Hi, first time I've had a chance to post here. Wish it was under better circumstances! I've got a 96 Legacy, 2.2 engine, 175,000 miles To start with, Daughter's BF got the urge to change the oil in it (without my knowledge)- about 5 miles from the house the car locks up- he forgot to put the Oil filter on! ArrrrgH!!!!!! So I decide it would probably be best to replace the engine- find a 95 EJ22 out of wrecked Impreza with 100,000 miles. Not worried about the differences in the exhaust ports (I'm owner of a muffler shop)- I decide to stick it in "as is". Everything goes together just fine, no problems- all the engine wiring, etc is the same- just had to change a couple of the mounting brackets, etc. In fact, I told my help I was amazed at how easy it was......... Famous last words. About this time I put my stupid hat on. While hooking up the lower Radiator hose, I decided to drain the oil out of it, and put new oil in. Change the filter, etc- let the car back down- start to add water- Holler at one of my help to start it up- don't want to cause a airlock in the cooling system..... Starts right up- hmmmm, need to figure out whats up with the idle- about 1500 rpm- but I start to add the water when I hear the sound of a timing belt strip and the engine dies. Sure enough- egine turns over - but the cams don't. WTF? About that time I notice the 5 qts of oil still sitting on the floor.... After several minutes of cursing my self in several languages- I decide to at least see where the damage is- pull the front covers off, yeppers, the belt is stripped... The Crank is feeling Ok.....the Drivers side cam is feeling ok...Passenger side- uggggh- it turns, but doesn't feel at all right- in fact, it feels bad! In total disgust with myself, I through down my tools and stomp out of the shop Next day, I prepare to start pulling that engine, still feeling sick to my stomach when my Dad happened by- he suggested it would hurt anything for me to try turning over that cam a few times- sometimes it will loosen up and be all right. I figure- Why not? can't really hurt anything. After giving it about 5 turns- it has loosened up considerably- so I decide to try putting a new timing belt on it. Found out about lining the shafts up iwth the Dots and lines, NP- heck of ingenious deal for Subaru IMO. GEt everything back assembled- turn it over by hand quite a few times- everything feels OK- feels like all four cylinders have Compression, Oil comes out of the heads, seems like it has oil pressure, I'm starting to feel pretty good again...... Put the Valve covers back on- put it all back together- Engines turns over, but won't start- It acts like it hits on a couple of the Cylinders, bu is also backfiring, and not sounding good at all- won't run. I've double checked everything I can think of- any suggestions? Quote Link to comment Share on other sites More sharing options...
sea#3 Posted January 1, 2005 Share Posted January 1, 2005 Recheck your timing marks . I'll bet the one on the crank isn't lined up Look for the mark on the reluctor of the crank gear and line it up on the notch that is just off centre of the crank sensor Whether the cam doesn't "SQUEEK" again I guess you are going to find out and hopefull the bottom end is going to be OK SEA#3 Quote Link to comment Share on other sites More sharing options...
DDad Posted January 1, 2005 Author Share Posted January 1, 2005 Hmmm, Reluctor- ummmm, that the 6 tooth ring at the back of the crank gear- I've seen it and I think I've seen the mark your describing- will look it over again tomorrow! Quote Link to comment Share on other sites More sharing options...
DDad Posted January 2, 2005 Author Share Posted January 2, 2005 OK- Maybe I'm confused- when I installed the belt- I lined it up with the mark on the gear- a triangle shape. Should I have lined it up with the mark on the "reluctor" portion? Considering that its about 90 degrees out- have to wonder why I have compression Quote Link to comment Share on other sites More sharing options...
cookie Posted January 2, 2005 Share Posted January 2, 2005 web site for mechanics. Somebody just posted a link a day or two ago and if I was not computer incompetant I would. It may clear up your confusion. We are all pulling for you as that was a dismal chain of events. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted January 2, 2005 Share Posted January 2, 2005 Hope this helps http://www.main.experiencetherave.com:8080/subaru_manual_scans/1999_Legacy_FSM/2_Engine_Section/2-03a_Engine_(SOHC)/MSA5TCD99L36.pdf SEA#3 Quote Link to comment Share on other sites More sharing options...
sea#3 Posted January 2, 2005 Share Posted January 2, 2005 WOOPS Wrong link try this one http://www.main.experiencetherave.com:8080/subaru_manual_scans/1999_Legacy_FSM/2_Engine_Section/2-03a_Engine_(SOHC)/MSA5TCD99L37.pdf SEA#3 Quote Link to comment Share on other sites More sharing options...
DDad Posted January 4, 2005 Author Share Posted January 4, 2005 Just a update: Didn't have much time to deal with it today- but did have enough time to Re-install the Timing belt- this time lining it up with the mark on the "reluctor"- it started right up! Now, running it for about 20 seconds with the exhaust off isn't a good indicator of long term health, or other problems, but the fact that it started at all made me feel considerably better Quote Link to comment Share on other sites More sharing options...
cookie Posted January 4, 2005 Share Posted January 4, 2005 then change the oil. You must have gotten wear particles from the cam freezeing. If you are lucky that saved your bearings. If it is idleing and it has a problem it won't toss a rod through the block and you could still save it. Quote Link to comment Share on other sites More sharing options...
DDad Posted January 4, 2005 Author Share Posted January 4, 2005 LOL well, I did change the oil (BEFORE starting it this time!) and as far as idling- suspect I've got to find a vacuum leak- lowest it would "idle" at was 1500 rpm Quote Link to comment Share on other sites More sharing options...
svxcess Posted January 5, 2005 Share Posted January 5, 2005 Neat story DDad....their's various sensors that make my 2.2 run at 1500rpm for the first minute or so...or if it's an auto just put in gear..should drop rpm...by the way does the daughters BF get to buy the new engine? Quote Link to comment Share on other sites More sharing options...
pearlm30 Posted January 5, 2005 Share Posted January 5, 2005 Ddad I hope you will resolve all the problems. BTW, where did you get that engine from? I am trying to locate a transmission for the same car. Also you mentioned you own a exhaust shop, where is it located at? I indeed need some exhaust work, any discount for board member? I am in St. Charles. Thanks Quote Link to comment Share on other sites More sharing options...
gbrand Posted January 6, 2005 Share Posted January 6, 2005 Glad to hear you got it running-when first read post was tempted to ask where you buried the boyfriend(just kidding). Certainly would look at Legacy777's page for instructions on re-learning the ECU at start up if had not done so already in documentation you have. Spent 1972-1984 in Missouri, still make it back couple times a year. Got my degree in Rolla, also where I convinced my older brother to buy the first Subaru I ever drove (a 77? 2 door) in 81 or so. I always wanted a Sub 4wd wagon to handle the winters on backroads up there, but wasnt able to get one till atfer I moved to Texas and picked my 80 up in 88. After I drove it in snow and ice I REALLY kicked myself for not having picked one up....... Good luck Quote Link to comment Share on other sites More sharing options...
simbey1982 Posted January 6, 2005 Share Posted January 6, 2005 I am trying to locate a transmission for the same car. Have a 4EAT with all the trimmings....see my post http://www.ultimatesubaru.org/forum/showthread.php?t=26892 Quote Link to comment Share on other sites More sharing options...
