Goodmorning everyone. Happy new year.
This morning I just discovered a leak under my car(1983 GL Wagon). It's accumalating on the crossmember and dripping down to the ground. I checked the heater hoses, and the two main hoses for leaks...nothing. It seems to be coming from the bottom of the engine. Some guy said something about "Freeze plugs" in the engine of other makes of cars. Is this true with Subarus? Has anyone else had this problem? COuld a Head Gasket blown on the edge of a coolant line and the outside of the head?
Thanks for your time.
[HTi]Johnson
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Unknown source of coolant leak.
Started by
[HTi]Johnson
, Jan 02 2005 01:14 PM
3 replies to this topic
#1
Posted 02 January 2005 - 01:14 PM
#2
Posted 02 January 2005 - 01:27 PM
i have a simular isse, but my leak is on top of the block. i thinki9 mine be the manifold gaskets or a loose hose. and the waterpump.
#3
Posted 02 January 2005 - 03:10 PM
Check the thermostat housing gasket. Mine leaked exactly as you describe. The coolant runs down to the bottom of the engine and drips from the bash plate. The small coolant hose that goes from the block to the intake manifold could also be leaking and produce the same results.
#4
Posted 02 January 2005 - 07:33 PM
also check the two small coolent crossover pipes, one starts from the back of the t-stat housing and goes to block and the other goes from base of carb on manifold to lower radiator line.
