how to remove a headlight bulb?
2 replies to this topic
#1 boogeyman
boogeyman
    New User
  • Pip
  • 1 posts
  • sacramento, ca
Posted 02 January 2005 - 02:31 PM
Vehicle: 1998 Subaru Forester
Problem: Left headlight bulb is burnt out. Works OK on high beam but not on low beam.
Action thus far: The power cord is disconnected, revealing the three prongs of the old bulb. At this point the directions read: "...remove retainer ring, then bulb." I can't see the retainer ring. Everything is covered by a rubber diaphragm (which presumably protects the back of the headlight assembly from moisture).
Questions: 1. Must the rubber diaphragm be removed to access the retainer ring?
#2 Suzam
Suzam
    1000+ Super USER!
  • 1,224 posts
  • Wilmington, Delaware
Posted 02 January 2005 - 04:05 PM
Yes, peel it off to continue.
#3 ashwinearl
ashwinearl
    New User
  • Pip
  • 5 posts
  • Blacksburg
Posted 11 January 2005 - 03:18 PM
Yes once the retainer clip is off, the bulb pulls out. It might be hard at first because the rubber seal might be sticky.
My 1998 Legacy has crappy lights, I replaced the bulbs with some from www.midnightmoose.com
I went with some higher wattage ones. No burned harness yet, and it was an improvement. The beam pattern still sucks though and I want to put some driving lights on as well.
