Guest Caboobaroo Posted August 6, 2003 Share Posted August 6, 2003 well I went to change the plugs on my 79 wagon and the plug in the #1 cylinder came out with an adapter cause someone stripped it out. So I wanna know if its easier to replace the head and not worry about fixing it, or should I fix it with a helicoil? I know the helicoils are like 40 bucks but I wanna do it right but if its cheaper to fix, I'll helicoil it. Quote Link to comment Share on other sites More sharing options...
Guest GeneralDisorder Posted August 6, 2003 Share Posted August 6, 2003 What's wrong with using the adapter they used? Just curious. Anyway - if there is nothing else wrong with the head, I vote for helicoil. Why toss a perfectly good head if it just needs a little attention? I'm sure that another head would cost more than $40. GD Quote Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted August 6, 2003 Share Posted August 6, 2003 was it an adapter or a different kind of thread insert, then a heli coil. If it was a different insert, you will probably need to replace the head. Quote Link to comment Share on other sites More sharing options...
Guest Caboobaroo Posted August 6, 2003 Share Posted August 6, 2003 when the adapter came out with the plug, it wouldn't come off of the plug. I think it should be the right size for a helicoil so I'm gonna try that Quote Link to comment Share on other sites More sharing options...
Guest Stupidru Posted August 7, 2003 Share Posted August 7, 2003 Take head to machinist, he'll fix it for $5.00. Quote Link to comment Share on other sites More sharing options...
