EJ-22 into 87 RX
11 replies to this topic
#1 CHIM
CHIM
    I think i can break that.
  • 366 posts
  • Oregon
Posted 12 January 2005 - 05:09 AM
Ok, i finally found a donor car, Im not sure what exact year it is but im asuming 92-94, Legacy sedan.
Found it in the paper for free, Motor runs, no tranny.
Is this motor gonna fit my tranny and motor mounts in the RX?
And will my RX ECU work with 2.2?
Also, Can the hubs from this car fix the rx as well.
Im a little exited to be picking this car up tomarrow:)
Any knowlege is VERY apprieciated!
~CHIM~
#2 CHIM
CHIM
  • 366 posts
  • Oregon
Posted 12 January 2005 - 05:23 AM
Oh, i forgot to aslo ask, is all the plumbing for the turbo going to work as well?
Exhaust and cooling & all that.
#3 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 12 January 2005 - 10:39 AM
Motor mounts are pretty close
tranny is not even close
turbo, if you want one will have to have all new exhaust stuff done.. stock RX turbo is too small anyway
wiring harness and ECU will have to be swapped.
You have a lot of work ahead of you. Hope you have some factory service manuals.
#4 subaru_styles
subaru_styles
    the 1st RX wagon!
  • 1,696 posts
  • OMGhi2U in da couve
Posted 12 January 2005 - 03:14 PM
you could always sell the RX to me:brow:
#5 CHIM
CHIM
  • 366 posts
  • Oregon
Posted 12 January 2005 - 04:13 PM
So, your saying that the 2.2 will not fit my 5 speed rx tranny?
And the turbo on the 2.2 won't fit my exhuast?
#6 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 12 January 2005 - 04:17 PM
You can adapt the Tranny to fit the EJ22.
The main question is... will the RX Tranny handle the power the EJ22T is capable of putting out?
-Brian
#7 CHIM
CHIM
  • 366 posts
  • Oregon
Posted 12 January 2005 - 04:22 PM
-Brian
Yet another dumb question, How would i go about adapting the EJ22 to my tranny?
I guess i'll see if the tranny can hold it after it's running:)
Also, will the LSD from the legacy fit EA81 aplications the same as EA82 LSD?
#8 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 12 January 2005 - 04:25 PM
That is correct. Neither the bellhousing nor the turbo is a direct bolt in.
However, as Brian said, a bellhousing adapter can be made.
A new exhaust system can be made as well. Some creative use of WRX exhaust parts will help a lot.
#9 CHIM
CHIM
  • 366 posts
  • Oregon
Posted 12 January 2005 - 04:32 PM
Ok, will the exhaust from the legacy donor car work?
Also, you said the tranny adapter has to be made?, They don't exist otherwise?
And does anyone happen to have one just layin around they might want to part with?.
The tools i have in my garage are limited in that matter.
This will be the first real mods i have done to a subaru, im sorry if i am anoying you guys with dumb questions.
But i really do appreciate all the help.
#10 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 12 January 2005 - 04:53 PM
Talk with Mudrat in Eugene about getting an adapter made for your tranny. You will want to have a whole new exhaust made up, would be the best way to do it.
If your keeping your RX Tranny, the LSD in the RX wont need to be changed. Your RX Tranny is 3.7 whereas a VLSD from a Legacy is 3.9.
-Brian
#11 ballitch
ballitch
    Certified Subaru Nut
  • 1,000 posts
  • Salem, OR
Posted 12 January 2005 - 08:17 PM
Does the RX tranny have the same bolt pattern as an EA82 D/R 5 speed?
#12 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 12 January 2005 - 08:23 PM
Sure does.
-Brian
