EA82 turbo to a EA81
14 replies to this topic
#1 Craven
Craven
    Just a guy with a Brat
  • 674 posts
  • Midland
Posted 18 January 2005 - 11:53 AM
Is it possible to fit the turbo system off a EA82 to a EA81 car? Aka 86 Brat.
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 18 January 2005 - 11:56 AM
If you wanted it setup like a factory type system, you would need a lot of EA81T parts.. Heads And such.
#3 Craven
Craven
  • 674 posts
  • Midland
Posted 18 January 2005 - 12:04 PM
Is that a compresion issue or a mounting thing?
#4 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 18 January 2005 - 12:56 PM
More of a mounting thing. The EA81T is MPFI like the EA82T.. So it would have the proper intake ports on the heads, which you current heads do not.
#5 Craven
Craven
  • 674 posts
  • Midland
Posted 18 January 2005 - 01:03 PM
The reason I ask, I might have a line on a pair of EA8T cars. A wagon with a nice body with a bad motor, not sure what's wrong with it, I didn't talk to the guy that long and a 3dr coupe with a good motor and a rusted out body. He got the cars, planning on doing a swap and selling the wagon. But he hasn't had the time to do it.
Then would rebuilding the bad engine, maybe with some cams and such and then installing that in the Brat be a better option? Depending what the problem is with the motor.
#6 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 18 January 2005 - 01:45 PM
Sure.. Install an EA81T in the brat.. it would be cool.. Make sure you have all the stuff you need before you scrap the donor though..Crossmember, ECU, wiring harness.. all that neat stuff
#7 Craven
Craven
  • 674 posts
  • Midland
Posted 18 January 2005 - 01:57 PM
You meen a EA82T, don't you?
#8 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 18 January 2005 - 02:08 PM
why? I think the EA-81 is a good engine to turbo, just get a cam ground with little over lap, and run a megasquirt, and either a spark box or EDIS. I think it'd be sick.
#9 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 18 January 2005 - 02:12 PM
not sure.. your last post said you had a line on a couple "EA8T" Cars, so I just took a shot in the dar..lol
yes, EA82T can be done as well.. more work.. But probably more fun as an end result.
#10 Craven
Craven
  • 674 posts
  • Midland
Posted 18 January 2005 - 02:22 PM
Sorry for typo, both cars are EA82T's
#11 Bratenstein
Bratenstein
    USMB Regular
  • PipPipPip
  • 123 posts
  • Dallas
Posted 23 January 2005 - 08:45 PM
Would an EA82T engine work with the Brat transmission? Or would I need to get a different transmission?
#12 Craven
Craven
  • 674 posts
  • Midland
Posted 24 January 2005 - 08:07 PM
It will bolt right up. Just use the clutch disk and throw-out bearing of the trans and the preasure plate and flywheel of the EA82 engine.
Craven
#13 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 24 January 2005 - 10:03 PM
why not just do a complete ea82t swap, block and everything? Its been done, and with mods you could be running mid 100s for hp.
#14 Vanislru
Vanislru
    Durka Durka!
  • 791 posts
  • Cumberland, BC
Posted 25 January 2005 - 12:05 AM
Garner has that sort of set up doesn't he? ea82t in a brat? ea82t's are so easy to mod and it sounds like you are familiar with what's involved with the swap so what the heck sounds good.
#15 Craven
Craven
  • 674 posts
  • Midland
Posted 25 January 2005 - 04:57 PM
I just might do that.
