Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
97 Imprezza won't restart in cold weather
#1
Posted 18 January 2005 - 12:34 PM
#2
Posted 18 January 2005 - 01:20 PM
#3
Posted 18 January 2005 - 01:46 PM
#4
Posted 18 January 2005 - 04:17 PM
Thanks for the answer. Don't know how full or empty the tank has been, or if there is a relationship. If the problem is fuel line freezeup, why would waiting 20 minutes matter?sounds like it could be something as simple as gas line freeze up...do you keep the tank topped up in the winter? do you have a block heater? do you add gas line antifreeze at all? We get very simialr weather here in eastern ontario It is -25 c right now with a wind chill of -37C and have learned through experience that if you let the tank run low and then sart up on a cold day run a short distnace then turn it off you can end up with a frozen gas line pretty quick..might seem too simple but sometimes we look for complicated solutions to simple problems..good luck
#5
Posted 21 January 2005 - 05:35 AM
I have got the same problem but independently by temperature. I posted it here somewhere a fortnight ago. When it happens, I just wait 15 to 20 minutes, then it starts again. I had it at the dealer's and it did not throw a code when it did not want to start anymore. After some testing the car started again and testing could not be proceeded. Really annoying. @Nug mentioned it might be the ECU.
#6
Posted 21 January 2005 - 09:46 AM
#7
Posted 21 January 2005 - 12:01 PM
#8
Posted 21 January 2005 - 12:29 PM
than an ECU. If an ECU gets the wrong input it is going to do the wrong thing.These are known to be a failure point. You could always move to Florida.
Jeeze Cookie, moving to Florida is cheaper than an ECU!
#9
Posted 21 January 2005 - 12:38 PM
I wouldn't be too worried about cold start capability there either.
#10
Posted 21 January 2005 - 01:28 PM
You need a systematic approach.
#11
Posted 21 January 2005 - 01:39 PM
Anyway, if it takes 15-20 minutes to restart the car, then that should give you plenty of time to figure out where the problem is coming from.
1. Do what you need to do for the symptoms to show themselves. Run car and shut off, etc.
2. Check for spark. If it has spark, move on to fuel system.
2a. No spark? Then it is crank or cam sensor, coil, ignitor, wiring, or ecu. Check for a voltage pulsation from cam and crank sensor while turning the engine over, check for 12v at coil, check for voltage at both outputs of ignitor.
Check for power at ecu.
3.Got spark? Then check fuel system.
3a. Do you have fuel pressure? Does the pump turn on when you turn on the key?
3b. Do the injectors fire while cranking? verify with a noid light.
If you run into some really weird isht like spark, but no injector output at all from ecu (checked directly at ecu) then I might suspect ecu. Some other sensors will cause a no-start, like MAF, possibly. Things like that need to be verified using the FSM. (I.E. if the ecu doesn't see the MAF, it may keep the injectors from firing. I don't know, but my factory service manual does).
Get a copy of the FSM, it has flowcharts of exactly what to check, step by step. Basically, a volt/ohm meter is the only tool really needed.
#12
Posted 08 February 2005 - 10:38 AM
Grey. Thanks for the information. This is beyond my abilities as a mechanic (basicly none) and besides, poking around inside the hood of a car, outside at 20 below isn't much fun. I appreciate your help, though.Ok, I'm mixed up.
#13
Posted 08 February 2005 - 10:40 AM
