'96 Impreza Wagon Intermittent Knock
3 replies to this topic
#1 Jason1976
Jason1976
    New User
  • PipPip
  • 18 posts
  • Bloomington
Posted 19 January 2005 - 01:18 PM
I recently purchased a used '96 Impreza Wagon w/ 215,000 miles on it. Over the past couple of weeks, there has been intermittent knocking in the engine. Usually the knocking only lasts for that particular "run time," only to dissapear the next time I start the vehicle. However, the knocking has been constant for the past three days. I have read in other threads that cold weather can have be a factor regarding knocking, and we have had several days of below-freezing temps. I'm hoping that this is what is causing the problem...I will have to wait out Mother Nature to be sure. I guess I'm asking for any alternative explanations in the event that the problem is not weather related.
The engine is 2.2L. I've had the plugs, wires, filters, and oil changed before the problem began. Yesterday I checked the oil level (which was fine) and tossed in some injector cleaner with my fill up. Another symptom I'm having is a loss of power at lower RPM's. The engine will not forcefully respond until I hit around 2500 rpms, and then it will lurch forward with the expected power. I had this problem before my tune-up and was expecting the tune-up to fix the "power" situation, which it did not. No engine lights are on.
Any suggestions/ideas are extremely welcomed. TIA.
#2 powderhound
powderhound
    Eat, Live, Breath Subaru
  • 359 posts
  • MSP
Posted 19 January 2005 - 02:59 PM
If the engine is knocking I would try a higher octane fuel. It is after all an anti-knock rating.
#3 unverviking
unverviking
  • 289 posts
  • Spencerport, NY
Posted 19 January 2005 - 03:12 PM
try a lower grade oil... 5W30, etc...
a lot of shops use 10W30 as their "bulk" oil. With sub zero temps, that get pretty thick..
#4 Jason1976
Jason1976
    New User
  • PipPip
  • 18 posts
  • Bloomington
Posted 19 January 2005 - 04:16 PM
I'm positive the oil is indeed 5W30. Is it possible that the oil would cause the other symptoms I'm experiencing?
