Crazy T-case idea, not what you think
10 replies to this topic
#1 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 19 January 2005 - 09:55 PM
So once you get the T-case you have two perfectly good stub shafts that are spinning as you're driving, and could also be spinning with the car at a stand still in 2wd, so heres the theory, make them a PTO, air compressor? thats all, just wanted to get this in print before i forgot.
#2 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 19 January 2005 - 10:22 PM
so the pto would be spinning all the time. it would work if you had a clutch like on the ac that could be turned on and off so that your air compressor isnt running all the time since the the front drive shafts are spinning in 2wd adn 4wd.
#3 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,367 posts
  • Seattle
Posted 19 January 2005 - 10:55 PM
Lumpycam already beat you to it buddy. . .
#4 RavenTBK
RavenTBK
    Professional Auto Thief
  • 661 posts
  • Apalachicola Natl Forest
Posted 20 January 2005 - 12:28 AM
Damn.. and thats a good idea too. Where his writeup? :lol:
#5 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 20 January 2005 - 12:42 AM
How about a pto winch?
some serious dragging power!
#6 monstaru
monstaru
    wow, relevance....
  • 4,452 posts
  • OlyWa
Posted 20 January 2005 - 12:54 AM
that would be some gearing down for sure!shouldn't be too hard though
#7 TheSubaruJunkie
TheSubaruJunkie
    I'M BAAAAAACK!
  • 1,938 posts
  • Sacramento
Posted 20 January 2005 - 03:31 AM
IN theory with an older FWD/4WD gearbox, in FWD the only stubs that are spinning are the front, and the rest of the car would virtually be in neutral. So a clutch type winch would be sweet. But the front diff is open, so you'd have to deal with that somehow.
-Brian
#8 Scoobywagon
Scoobywagon
    Evil Genius (tm) for Hire
  • 1,044 posts
  • Bremerton-like
Posted 20 January 2005 - 04:42 AM
Got this idea about a year ago and am currently trying to accumulate the parts. I'll use DOJ cups to attach a variable displacement hydraulic pump to each axle stub. These will be plumbed "in parallel" to each other and will run a military type hydraulic winch mounted at the vehicle's center of gravity. a roller fairlead will be mounted above it so that the center-mounted winch can pull the vehicle in any desired direction, to include straight up.
#9 RavenTBK
RavenTBK
  • 661 posts
Posted 20 January 2005 - 12:25 PM
I thought of that same thing when I first read this thread. It can be easily solved by putting a couple of tack welds onto one stub to hold it still. Voila! Instant "locker". :grin:
Maybe a lil piece of steel or something set up at an angle from the top of the stub down to the case. Something that can easily be removed and wouldnt fark up the seals there at the stub. It wouldnt take all that much pressure/strength to lock down one side..
#10 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 20 January 2005 - 12:37 PM
What does he have setup running off the stubs?
#11 mudrat79
mudrat79
    Banned
  • Banned
  • 697 posts
  • Eugene,
Posted 20 January 2005 - 01:00 PM
If My memory serves me correctly....( it's been a Year plus since I saw It....)
What he did was Took a CV cup, and Welded a Pully to it, then up where spare should have been he set up a York compressor with a pully as well....What he did for clutch to run it was just a idler pully that cammed over a fucrum point to tension up the belt enough to run the compressor.....
Put it on the passenger side as it is normally your driver/power side in the trans.....In 2WD mode you can run any gear......
You will have to play with different pully set ups, as his worked, but not as well as it could or should have.....
We thought up the Idea before the Rubicon trip while we were sticking the BEAST together......I wanted to do it as well, but didn't have the time......
Have fun, John
