Oil Seals myself or mechanic???
14 replies to this topic
#1 91 loyale in Syr
91 loyale in Syr
    New User
  • PipPip
  • 12 posts
  • Syracuse, NY
Posted 31 January 2005 - 10:21 AM
My 91 loyale has the oil leaks coming from the front. Not sure which seals are leaking but Im under the impression that if I go in there I should do them all. I brought it to the local independent shop and they said they would replace the waterpump(appears to be leaking) the cam and crank seals and both timing belts for $475. He said the timing belts get compromised when they get oil on them. I have a lot of mechanical experience and could probably do it myself if I had a garage, there wasnt snow on the driveway and it wasnt 15 degrees outside. I looked inside and it looks pretty tight in there. Is this job done from the top or bottom? Is this a good price to have someone else do it? Any advice/thoughts on the subject would be greatly appreciated. Thanks in advance!
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,092 posts
  • East Coast
Posted 31 January 2005 - 10:34 AM
done from the top.
475 sounds about right for seals, water pump and timing belts. could be found cheaper, but that's not terrible. make sure he reseals the oil pump properly. there's one gasket and one seal on the oil pump shaft. a nonsubaru specialist could easily miss doing that right. same goes for the cam shaft, behind the seal holder of the cam shaft is an oring that also should be replaced. it comes in a camshaft seal *kit* which includes the seal and oring.
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 31 January 2005 - 11:25 AM
you could do it yourself if you like, just know the right procedure that makes it easiest. work from the top. if youre doing the water pump remove the radiator but other than that it can be done without opening the cooling system
the ac/alt assembly will come off as one piece. remove the long hexd bolt, and the other bolt closest to the crank just loosen it. flip up the alternator and remove the 12mm bolt from the bracket, and the 14 on the intake. you may have to remove the adjustment pulley, if its the left hand type screw be sure to loosenthe nut on the pulley!
you can change a belt with all this on but if youre driving seals you will want the room
you have to remove the crank pulley and dipstick to remove the plastic. the bolts on the bottom of the plastic there are nuts behind. sometimes the fittings crack, use even torque. if the bolt just spins you can pop the cover off with mild persuasion from a screwdriver
since you will take it apart down to the seals you may as well pitch the plastic covers if you figure you will be under the hood often this is convenient. if you changed a timing belt it would take 10 minutes and not 3 hours. i recommend it form my own example, as others will, and to me it seems with the absence of covers any leaking oil will drip away instead of collecting on the timing belts
its fun you should give it a try
#4 85Sub4WD
85Sub4WD
    EA82 Junkie
  • 1,244 posts
  • Raleigh NC/Charlotte NC
Posted 31 January 2005 - 11:33 AM
I would not pitch the plastic covers, as ANYTHING (particularly a small stone or bit of gravel) that could get on the teeth of the timing belt could cause it to snap, and leave you cursing by the side of the road. (I have seen this happen to a car before) The covers are there to prevent that. That said, you could punch some *small* holes in it and vent the T-belt that way.
Better still, fix the leaks.
#5 idosubaru
idosubaru
  • 24,092 posts
  • East Coast
Posted 31 January 2005 - 11:52 AM
if a timing belt snapped due to something getting in the teeth, how would you know after the fact?
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 31 January 2005 - 12:07 PM
not to turn this topic into an arguement but a stone is highly unlikely to throw a belt. most likely it will be kicked out. it is even more likely a stone would never make it to the timing belts to begin with. anyway i go off road with open belts thru shrubs and 6ft tall weeds, gravel, mud, never had a problem with reliability
anyone here running open belts would swear bt them
the only reported belt failure was due to a loose rag under the hood. it took 10 minutes to fix off the side of the road, with 3 tools
all i am saying if you like to play with soobs its more convenient. if it breaks so what fix it in 10 minutes, keep a spare in the trunk. it saves you from having to remove ANYTHING to change a timingbelt, other than the alt/ac belts. if you cnange the oil pump or water pump you dont have a bunch of crap top remove
opinions will differ, but there are the ones who know and the ones who dont
#7 stephenw22
stephenw22
    Certified Subaru Nut
  • 877 posts
  • SK, Canada
Posted 31 January 2005 - 12:22 PM
The covers/no covers issue is one that comes up every now and again. If you are into doing all of your own maintenance, just leave them off and keep an old set of belts in the car as a spare. If you're going to have a shop do it, just leave the covers on. From my experience, yhey charge you by the hours it says in their book, whether or not the covers are there.
I've been running on gravel roads for about 1 year now using my '88 that has no covers. Before that, it spent about 1 year doing city/highway driving. I've never had problems with broken belts, and I've been through tons of nasty mud. I was actually a little worried because this last summer was one of our wettest in history, and the roads became horrible, but nothing broke. I didn't even wash the car until the fall. The first time I do any t-belt or re-sealing work on one of my cars, the covers are the first thing to go.
#8 85Sub4WD
85Sub4WD
    EA82 Junkie
  • 1,244 posts
Posted 31 January 2005 - 12:28 PM
When the stone fell, it scarred all the pulleys and got jammed in the vicinity of the oil pump (so it was still there). I don't know if it was a freak ocurance, or if it is a real possibility, but I personally would not take the risk as I use my soob as a daily driver.
Really, it does not take long to install/remove the covers, the hard part is getting the crank pulley bolt off. (and it really isn't that hard if you put a screwdriver in to lock the flywheel. Other than that, it is pretty straitfoward and easy. I doubt if is really even necessary for the radiator to be removed (especially if you have a good angle on the wrench), though it does add space.
#9 91 loyale in Syr
91 loyale in Syr
    New User
  • PipPip
  • 12 posts
  • Syracuse, NY
Posted 31 January 2005 - 12:49 PM
Are these seal kits readily available at auto zone or napa?
#10 hooziewhatsit
hooziewhatsit
    I fix old cars
  • 1,333 posts
  • Klamath Falls
To change the cam seals, it looks like all you have to do is take the timing pulleys off, remove the camshaft support, then replace the seal around it, right?
My wife's loyal has oil everywhere, so I'm planning on doing this job sometime as well.
About the timing belts, couldn't you cut the cover that's behind the crankshaft pulley in half? Would that give you enough room to remove it with the pulley still on? It's been a while since I looked at mine to see.
Also, you could still run with that cover off, but the two other covers on.
my 0.02c
#11 stephenw22
stephenw22
  • 877 posts
  • SK, Canada
Posted 31 January 2005 - 01:32 PM
For each camshaft holder, there is a seal and an o-ring. Also, don't forget about the crank seal.
I have this as a 3-4 year ritual on my cars. This is what I do:
cam seals / o-rings
cam case o-rings
oil pump o-rings / seal
front crankshaft seal
timing belts
water pump o-ring
oil pump (if necessary)
water pump (if necessary)
valve cover gaskets / grommets (if necessary)
other hoses, etc. (if necessary)
The cam seals and cam case o-rings seem to start leaking after 2-3 years, but I just wait until it's time to change timing belts before I do everything. Even then, the leaks have never been too bad.
#12 85Sub4WD
85Sub4WD
    EA82 Junkie
  • 1,244 posts
Posted 31 January 2005 - 03:26 PM
Case in point - my soob still has its original seals at 145k (all city) and I don't leak (much) it eats less that a quart per 3,000 miles.
#13 Tom63050
Tom63050
    Subaru Fanatic!
  • 373 posts
  • St. Louis
Posted 31 January 2005 - 04:22 PM
By all means do it yourself. Just keep putting oil in it until it warms up enough that you feel like doing it. So it costs you a couple of quarts, so what?
I'm reasonably mechanically skilled, a little more than oil changes, and have done oil pump seals, cam seals, the front crank seal, and belts. Also put on my lift kit. It's all very doable and there is plenty of expertise here to get you through it, either archived or you can ask questions and get responses. The hardest part is getting up the courage to try something new, like that first jump off the high dive.
I wimped out on chucking the timing belt covers. Did a compromise and cut the center cover in two so I could get it off easily. Removing my covers adds about 3 minutes to the job. If you keep them on, use anti-seize on the bolts.
About the water pump appearing to be leaking: there is a metal pipe between the top radiator hose and the oil pump. The leak might just be the o-ring that seals the metal pipe where it connnects to the water pump. Get a new o-ring, lube it with oil/grease (antifreeze hasn't worked for me there as a lubricant), and slip the pipe back onto the water pump. Cheap, simple, easy fix that just might be all you need.
#14 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 01 February 2005 - 03:46 AM
Listen to MilesFox. HE knows what hes talkin about . Open covers are the way to go. some members will say that you'll get oil or antifreeze on your t-belts.. yeah you might, but it will just spin off any oil or antifreeze that gets on them, instead of oil/antifreeze leaking into the covers and spinning around inside the covers and constantly recoating the belts.
to what Tom63050 said about the waterpump pipe. - if you ever take that out, you HAVE To replace the oring. they are a one time use oring. you may get a second use out of it, but its gonna suck when the oring finally goes and you crack some heads because you didnt change the 10 cent oring
85Sub4WD - "the hard part is getting the crank pulley bolt off. (and it really isn't that hard if you put a screwdriver in to lock the flywheel."
This is the EASIEST PART OF THE JOB. put a 22mm on a 1/2" 18 inch breakerbar. on the crank pulley bolt. now brace the breaker bar against the core support on the driverside of the car. (where the raid sits against on the buttom) now unplug the coil to disty wire and bump the starter for about a half second. Done deal....
#15 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 01 February 2005 - 09:06 AM
NAPA will have gasket sets but they may be soewhat pricey. i know that you can get a PAIR of head gasets at napa fopr the price of ONE gasket at autozone, but i live in indiana where subaru parts are NEVER in stock, and un available half the time(a-zone, advance)
it would be more economical to but the gaskets separately, as if you get an entire "reseal" kit wit will come with gaskets for turbo, spfi, and carb, and you will have extras
a head gasket set itself from napa is about 80-90 bones, it will have the head gaskets, valve seals, the o-rings for the cam towers(very important) and i think also intake and exhaust gaskets
if you get headgaskets individualy you will have about 50 in for a pair, the o=rings cab be had at a hardware store
cam, crank, intake and exhaust seals will averager about 5 bucks apiece, the intake and exhaust will come as a pair
depending on your shopping you should score everything within 75 to 100 bucks depending on what set(s) you may get or where you get individial seals
