TWO Legacies wouldn't start!
25 replies to this topic
#1 gcleeton
gcleeton
    USMB is life!
  • 139 posts
  • Allegany
Posted 31 January 2005 - 02:04 PM
Hello
It's been pretty cold here in the snow in NY State so I put my 2 Legacy Wagons 96 and 99 in the garage and put the gas heater on overnight.
Next morning neither of them would start until I left them out in the cold.
Why please?
Gil (newbie to USA from UK!)
#2 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 31 January 2005 - 10:30 PM
but that does seem pretty strange.
#3 91subaru-Bruce
91subaru-Bruce
    New User
  • PipPip
  • 27 posts
  • Vancouver
Posted 01 February 2005 - 01:29 AM
That is strange. Only thing I can think of is some kind of "vapor lock" from warming them up after being outside in the cold???
Weird. If it happens again, try releasing the gas cap to see if there is pressure built up.
#4 sea#3
sea#3
    Subaru Fanatic!
  • 354 posts
  • Vancouver Canada
Posted 01 February 2005 - 03:10 AM
Was it a Catalytic type gas heater , if so there may have been not enough oxygen ?
SEA#3
#5 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 01 February 2005 - 07:02 AM
I don't think vapor lock is a problem on F.I. autos, what with the pressure the fuel system is under.
Do you mean they wouldn't crank, or they were cranking and wouldn't fire?
#6 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 01 February 2005 - 07:36 AM
WOW, this has got to take some kind of prize as the weirdest problem. In my over 40 years of working on cars, I have never heard anything like this. There has got to be a simple explaination. So you drove them into the garage, what did you do then? In the morning (or whenever), when you went to start them, what exactly did you do? How did you get them out in the cold again?
#7 gcleeton
gcleeton
    USMB is life!
  • 139 posts
  • Allegany
Posted 01 February 2005 - 02:05 PM
It was a cold day.
When i returned from trips out I drove them into the garage and left them overnight with the gas heater on and doors closed.
The next morning both of them would crank but not start.
I pushed them outside for half an hour and they started first touch as usual.
Gil
#8 cookie
cookie
  • 3,058 posts
  • SFO
Posted 01 February 2005 - 02:39 PM
the lack of oxegen.
#9 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 01 February 2005 - 09:15 PM
I think there was a Car Talk Puzzler similar to this: Some cars were stuck in traffic due to a smokey field fire. When the traffic was allowed to go the cars with the oxygen sensors wouldn't start. I just guessed that was the answer, I never checked.
#10 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 01 February 2005 - 10:25 PM
I was WRONG!!! I just went to the Car Talk website and I was WRONG, Wrong. wrong. I guess I don't know why your cars don't start either. Maybe the tire presure is low, that sounds about as good as my last guess.
#11 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 02 February 2005 - 07:42 AM
That is really a wierd problem, I can't think of anything that would cause that, it just doesn't make any sense. If there was enough oxygen for you to breath while trying to start the cars, there was enough to run the engines.
#12 ron917
ron917
    Subaru Fanatic!
  • 431 posts
Posted 02 February 2005 - 07:53 AM
The answer is really very simple: the cars simply did not want to leave their warm resting place on a cold morning. I don't blame them, I also prefer to stay in my warm bed in the morning. :rolleyes:
#13 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 02 February 2005 - 10:46 AM
Case closed. Next?
#14 91subaru-Bruce
91subaru-Bruce
    New User
  • PipPip
  • 27 posts
  • Vancouver
Posted 02 February 2005 - 11:42 AM
I'm starting to think it might be the blinker fluid or muffler bearings. Check those and let us know what you find ;)
#15 bearbalu
bearbalu
    USMB is life!
  • 182 posts
Posted 02 February 2005 - 12:54 PM
Here is my theory: Coolant temperature sensor and lack of Intake Air Temperature sensor.
Coolant temperature sensor. Keeping the car inside makes the computer think temperature outside is 60F - or what ever in your garage. So computer would plan for a 60F cold start and send limited fuel. You must have opened the garage door to start and get the car out - that let in a lot of cold air. The incoming air is much colder and computer isn't sending enough fuel, since coolant is at 60F.When you put the car out, engine coolant gets cold, computer senses it, and sends enough fuel.
I can't find Subaru Intake Air Temperature Sensor on a Subaru, that would explain it too...
It is possible the problem is entirely something different and not related to car being in warm/cold setting. The act of pushing the car out from garage could have done something. The act of cranking the engine a few times might have done something - may be they would have started inside the garage later too...
Is this the first time you took the car into garage and put the heater? Any previous history?
#16 bearbalu
bearbalu
    USMB is life!
  • 182 posts
Posted 02 February 2005 - 02:03 PM
I am not sure whether Mass Airflow Sensor in Subarus somehow figures out Intake Air Temp through air mass - colder air would be heavy. I understand some MAF have a built in Intake Air Temp sensor. In either case, I suspect big differences in air/engine temp might have thrown off the computer, not sending enough fuel.
#17 mikem
mikem
    USMB Regular
  • PipPipPip
  • 90 posts
  • greensboro
Posted 02 February 2005 - 04:39 PM
Seems like the lack of oxygen would also effect the heater and the set of lungs that were both present.
I've seen fuel injected aircraft engines with vapor lock caused by heat soaking.
However, since you are recently from the UK, maybe you just got in the wrong seat through habit and put the key in the glovecompartment lock!
Let us know what you find out.
#18 cookie
cookie
  • 3,058 posts
  • SFO
Posted 02 February 2005 - 05:12 PM
Put the cars in the garage without the heater. I bet they start right up. It would not take all that much to throw off a current lean burning FI engine.
#19 gcleeton
gcleeton
    USMB is life!
  • 139 posts
  • Allegany
Posted 03 February 2005 - 08:40 AM
Both of the cars will start if the gas heater is off.
They won't start if the heater is on.
The garage is very damp when heater is on melting the ice.
Are Legacies susceptible to damp?
Gil
#20 cookie
cookie
  • 3,058 posts
  • SFO
Posted 03 February 2005 - 11:04 AM
in the Pacific NW.
#21 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 03 February 2005 - 01:19 PM
My 90 Leg would not start in the damp, I am in PA. I spent ALOT of time trying to find out why, even to the point of unwrapping the wire harness looking for bare wires. When it is damp and not starting do your fans come on? My problem was that when it was damp something told the car that it was warm/hot when is wasn't. Sent the wrong gas mixture?
#22 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 03 February 2005 - 01:24 PM
Did you test the coolant temp sensor connector and circuit? It would be a likely culprit.
#23 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 03 February 2005 - 01:34 PM
YEP, put in a new one, also used jumpers to send signals when the new one made no difference.
#24 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 03 February 2005 - 02:01 PM
Never heard of dampness being a problem, if it were, there wouldn't be any Legacys in the Pacific Northwest, noted for it's large amounts of rain.
#25 blackbart
blackbart
    tlegacy driver
  • 449 posts
  • Northeast PA
Posted 03 February 2005 - 04:37 PM
I ONLY had the problem in the rain or a REALY damp/foggy type day.
Changed the ECU without results. The ECU I took out worked in the doner car.
